Troy,
Jerry Boyle was kind enough to send a copy of his file. Once I was able to
get Outlook to release its grip on the "dangerous" attachment. It was
exactly what I needed. All I was trying to do was to generate a time based
serial number for an AIAG bar code lable.
Shirley
Sent: Wednesday, June 05, 2002 3:10 PM
Subject: Re: [Vantage] This Should Be simple, Shouldn't it??
Shirley,
Just as Jerry said, there are a couple hundred Crystal Functions defined
in help in Crystal. Which one are you looking for? Here is one example
from Crystal 8.0 Professional:
Troy Funte
Liberty Electronics
Average (fld), Average (fld, condFld), Average (fld, condFld, cond), Average
(x)
Basic and Crystal syntax.
Arguments
a.. fld is any valid database or formula field that can be evaluated by
the function.
b.. condFld is a field used to group the values in fld by.
c.. cond is a String indicating the type of grouping for condFld. You only
specify this argument when condFld is a Date, Time, DateTime or Boolean
field. For more information on the valid strings for this argument, see
Conditions for summary functions.
d.. x is an array of values that can be evaluated by the function being
used.
Returns
Fractional Number
Action
Enables you to average the values that appear in your report. For example:
a.. If a sales report includes a field that shows the amount of each
order, you can compute the average of all the orders that appear on the
report (a grand total average). For information on this kind of summary, see
SummaryFunction (fld).
b.. If you break orders into groups (for example, orders grouped by the
state that they come from), you can compute the average order per group (in
this case, per state). For information on this kind of summary, see
SummaryFunction (fld, condFld).
c.. If you break orders into date or Boolean groups (for example, orders
grouped by the month in which they were placed), you can compute the average
order per group based on a particular change in the date or Boolean field
(in this case, per month). For information on this kind of summary, see
SummaryFunction (fld, condFld, cond).
d.. If you specify an array of individual values, you can also compute the
average value in the set. For information on this kind of summary, see Array
summary functions (x).
Examples
The following examples are applicable to both Basic and Crystal syntax:
Average({orders.ORDER AMOUNT})
Calculates the average of all values in the Amount field.
Average ({orders.ORDER AMOUNT}, {customer.CUSTOMER ID})
Finds the average amount of a sale made to each customer.
The following example is applicable to Crystal syntax:
Average ([10,12,32,48])
Calculates the average of the values in an array of constants.
Note: Using this function in a formula forces the formula to be evaluated
at print time. For more information on evaluation time considerations, see
Evaluation Time functions.
Seagate Software, Inc.
http://www.seagatesoftware.com
Please send comments to:
techpubs@...
Shirley
Shirley,
Troy Funte
Liberty Electronics
(x)
Arguments
the function.
used.
Returns
Fractional Number
Action
Examples
techpubs@...
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Wednesday, June 05, 2002 10:11 AM
Subject: RE: [Vantage] This Should Be simple, Shouldn't it??
> Shirley, in CR Help > index >"function", I get a list of every function
with
> the info you want.
> Jerry Boyle
> Sipco Molding Technologies
> Meadville, Pa. 16335-6725
> 814.724.2243 x53
> vantage 5.00.337
> From: Shirley Graver [mailto:shirleyg@...]
> Sent: Wednesday, June 05, 2002 9:14 AM
> Subject: [Vantage] This Should Be simple, Shouldn't it??
> Simply put.... Very easy Crystal report, I want to use a function that I'm
> not sure of. I pull out the manual check the index, no apparent function
> list. Go to help no apparent function list, go to website, it dances
around
> functions and doesnt deliver, search on google same thing. All I want to
> see is a list of Crystal functions, proper syntax and an example of its
use,
> like report builder. This should be simple..... Shouldn't it?? Thanks if
> anyone can help.
> Shirley Graver
> Systems Administrator
> Rubber Associates Inc.
> Cleveland/Akron, OH
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
