Hi Bruce ,
Thank you for reply.
Detail for Point 2 is i have 5 opertions againt job. time and expense entry starter with person and then you select job and related operations.How i will know which operations is/are pending to completed in EPICOR?against any job?
Detail for point 3.
Posting Operations means complete the operations in EPICOR by doing several entries.If answer is yes how can i view that attachement later ( I mean 1 or 2 or 6 months later)?
Hi Vinay,
Thank you for your reply.
Can i see any attchments here which was attached during time and expense entry?
I mean if there is any inspection operations for the job and inspection was carried out by ispector and some report (Pdf/word etc)attached during operations completion a T & E screen?
Or other way how and where can i see all documents attached during time and expense.?
I do not know about the attachments from inspection, but I am able to see attachments from Part Revision in the Job Tracker. You will have to test for your use case.
