Time change - this is weird
Okay My Version of MSVCRT40.dll
winnt\system32 directory = 4.20
Vantage\dll directory = 4.10.6038
progress\bin\system = 4.10.6038
I also tried removing the Check mark in "automatically ajust to
daylight....." I reset the server time, (taking it out set the time back).
When I reset the time on the server, the time in Data Collection and Pro
Control, and ProMon are saying the right time. Report Builder isn't. But
this is better then all of them being wrong. So thanks Sharon.
Nancy Dunn
Sent: Monday, April 02, 2001 10:24 AM
Subject: RE: [Vantage] time change - this is weird
Let's check what version of MSVCRT40.DLL everyone is running. We
don't seem to be having any problems, on the Vantage server our version of
MSVCRT40.DLL is:
winnt\system32 directory = 4.20.6172
My time was off also, so I took the check mark out and checked the time in
Data Collection. The time was 2 hours behind. I put the check mark back in
and checked Data Collection the time was were it should be. After typing
this far, I just check Data collection again. It is a hour behind!!!!
Nancy Dunn
Winco Industries Inc.
Sent: Monday, April 02, 2001 9:12 AM
The time was wrong on our Vantage database and I took the check mark off on
the automatically adjust for daylight savings time on the server and it
worked
We are having the problem as well, however, the time in Data Collection is
correct, but the time on our report builder reports is an hour behind. I am
on 4.00.904, Progress 9.0B.
v5 is running ok. Maybe this is the problem?
http://www.msnbc.com/news/551861.asp
> Nancy Dunn
> From: Sharon Fox [mailto:sfox@...]
> worked
> To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Nancy I just left the check mark off and ours is working find.
Sent: Monday, April 02, 2001 8:25 AM
To: 'vantage@yahoogroups.com'
Nancy Dunn
worked
There hasn't been much good to say (in terms of bugs) about V5 so I'll have
to second that. v5 is working OK. But my computer based phone system
isn't, but that's another story. Thanks Joe for that heads up info. Looks
like that is the key to the problem.
Darren Mann
Miller Products Co.
> From: Joe Konecny [mailto:jkonecn@...]
> Sent: Monday, April 02, 2001 8:42 AM
> Subject: Re: [Vantage] time change - this is weird
> checked the time in
> check mark back in
> After typing
> behind!!!!
> > Nancy Dunn
> check mark off on
> server and it
> > worked
> enable access.
> ------------------------ Yahoo! Groups Sponsor
> Find software faster. Search more than 20,000
> software solutions on KnowledgeStorm. Register
> now and get started.
> http://us.click.yahoo.com/kVJDAA/zMSCAA/Ig4EAA/P0AVlB/TM
> -------_->
> enable access.
This is just weird. I took the check mark out again & refreshed the Pro
Control. It has the right time. Report builder and Data Collection is
still an hour behind.
Ver: 4.00.904 Prog: 9.0B37
Nancy
Sent: Monday, April 02, 2001 10:04 AM
I agree! I think that after next weekend the "bug" will be gone.
Especially because Jerry Boyle said that he changed the date on his
workstation to April 8 and his RB reports printed ok.
Wendy Bowen
Network Administrator
Schmald Tool & Die, Inc.
(810) 743-1600 ext.323
wpursche@...
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Monday, April 02, 2001 10:12 AM
have
Looks
> Darren Mann
> Miller Products Co.
> > checked the time in
> > check mark back in
> > After typing
> > behind!!!!
> > > Nancy Dunn
> > check mark off on
> > server and it
> > > worked
> > enable access.
> > -------_->
> > enable access.
You may be onto something, here is an article from TechNet.
Microsoft Run Time Library file (msvcrt40.dll)
Some applications that utilize this runtime library may behave
as if the current time is one hour earlier than the correct time
shown on the Windows clock. The problem will continue for one
week from April 1 through April 8, 2001, after which these
applications will shift to daylight savings time and again be in
sync with the operating system. The problem results from the fact
that April 1, 2001, falls on a Sunday, which confused a small
algorithm in the run time library file that checks for the start
of daylight savings time.This is not a year 2000 issue but rather
a daylight savings time issue. It could occur in the years 1973,
1979, 1984, 1990, 2001, 2007, 2012, 2018, 2029, and 2035. What is
common about these years is that April 1st falls on a Sunday.
Let's check what version of MSVCRT40.DLL everyone is running. We don't seem to be having any problems, on the Vantage server our version of MSVCRT40.DLL is:
v5 is running ok.� Maybe this is the problem?
> Data Collection.� The time was 2 hours behind.� I put the check mark back in
> and checked Data Collection the time was were it should be.� After typing
> this far, I just check Data collection again.� It is a hour behind!!!!
> Nancy Dunn
> worked
> To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/.%ef%bf%bd Note:� You must have already linked your email address to a yahoo id to enable access.
Click Here to Find Software Faster
To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/.%ef%bf%bd Note:� You must have already linked your email address to a yahoo id to enable access.�
I can confirm this also; Changing the client to April 8th, fixed the report
builder reports printed on the client to the correct day light savings time.
But be careful if you have OutLook running with a lot of reminders for next
week. <grin>
Patrick
Vantage 4.00.901, Progress 9.0B37
Sent: Monday, April 02, 2001 9:17 AM
Wendy Bowen
wpursche@...
have
Looks
> Darren Mann
> Miller Products Co.
> > checked the time in
> > check mark back in
> > After typing
> > behind!!!!
> > > Nancy Dunn
> > check mark off on
> > server and it
> > > worked
> > enable access.
> > -------_->
> > enable access.
