Time Editor Blank Title 100547
Jim,
So damn easy and yet so elusive.
Thanks, worked perfectly.
Scott
jckinneman
Sent: Thursday, June 23, 2011 11:52 AM
Subject: [Vantage] Re: Time Editor
EpiTimeEditor controls expect an integer that represents the number of
seconds since midnight.
Jim Kinneman
Senior Consultant
Encompass Solutions.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Scott
Litzau" <scott.litzau@...> wrote:
> I have looked at the properties and methods previously.
> Here is my issue, I can set a variable to DateTime, which is in a long
> format, (Month, Day, Year, Hour, Minute, Seconds)
> then convert that to a Short Time String using
> variableName.ToShortTimeString() method.
> But I get the following when trying to assign the value to the Number
field.
> The TimeEditor field has to be a Number (Decimal) otherwise you get an
> Invalid Cast when launching the form.
> The following application error was encountered:
> Input string was not in a correct format.Couldn't store <2:00 PM> in
> Number02 Column. Expected type is Decimal.
> So I attempted to convert (System.Convert.ToDecimal) the String back to a
> Decimal and get the following
> Which is most likely due to the AM/PM designation or the : (colon). And
> looking at the AddHours or AddMinutes methods they only are Returns (Gets)
> not Sets.
> Scott
> -----Original Message-----
Behalf Of
> Waffqle
> Sent: Thursday, June 23, 2011 10:01 AM
> Subject: Re: [Vantage] Time Editor
> >From customization mode, go to Tools > Object Explorer.
> Click the 'Data Objects' tab.
> Find the dataView you want to play with, expand to the field you want and
it
> will give you the code you need.
> On Thu, Jun 23, 2011 at 9:14 AM, litzer1 <
> <mailto:scott.litzau@...> scott.litzau@...
<mailto:scott.litzau@...%3ewrote> >wrote:
> > Does anyone have a VB example on how to set the time in a Time Editor
> > field.
> > Thanks,
> > Scott
> *Waffqle Driggers*
> *High End Dev, System Design, Profit Drinking
> *:: 904.962.2887*
> *:: <mailto:waffqle@...*> waffqle@...*
> *:: NO FAXES*
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> <http://groups.yahoo.com/group/vantage/files/>
> <http://groups.yahoo.com/group/vantage/messages>
> <http://groups.yahoo.com/group/vantage/linksYahoo>
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> <http://groups.yahoo.com/group/vantage/>
> Individual Email | Traditional
> <http://groups.yahoo.com/group/vantage/join>
> (Yahoo! ID required)
> <mailto:vantage-digest@yahoogroups.com
<mailto:vantage-digest%40yahoogroups.com> > vantage-digest@yahoogroups.com
> <mailto:vantage-fullfeatured@yahoogroups.com
<mailto:vantage-fullfeatured%40yahoogroups.com> >
> <mailto:vantage-unsubscribe@yahoogroups.com
<mailto:vantage-unsubscribe%40yahoogroups.com> >
> <http://docs.yahoo.com/info/terms/> http://docs.yahoo.com/info/terms/
I am trying to use the time editor vs the datetimeeditor for the first time.
I keep getting an error "Object cannot be cast from DBNull to other types"
It is tied to a date field, I also tried a shortChar field but I cannot get it to work either way. What simple step am I missing here?
I figured it out, it is using an integer not a date field to store for the epiTimeEditor. Set it to a number field and it works.
Does anyone have a VB example on how to set the time in a Time Editor field.
Scott
Find the dataView you want to play with, expand to the field you want and it
> field.
> Thanks,
> Scott
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
But I get the following when trying to assign the value to the Number field.
not Sets.
Scott
Waffqle
> field.
> Thanks,
> Scott
*Waffqle Driggers*
*:: 904.962.2887*
*:: NO FAXES*
<mailto:vantage-digest@yahoogroups.com> vantage-digest@yahoogroups.com
<mailto:vantage-fullfeatured@yahoogroups.com>
<mailto:vantage-unsubscribe@yahoogroups.com>
EpiTimeEditor controls expect an integer that represents the number of seconds since midnight.
Jim Kinneman
Senior Consultant
> not Sets.
> Scott
> Waffqle
> > field.
> > Thanks,
> > Scott
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: NO FAXES*
