Time Integer Blank Title 140633
Thanks for the response, Brenda.
I am trying to auto-add an hour to the Need By Time field.  I can add 3600 (for an integer hour) to the field but I had it triggering off the oprseq field change and it would potentially keep adding up on multiple changes.  Hence, my question for the current time function in integer format.
I will try the form load method instead and see if that works. That will just add it once and be done with it.
Thanks again,
Ross
E10.1
I am working in the Get Request screen and am wondering how to get the current time in an integer format?
The NeedByTime is stored this way and I would like to have something equivalent to DateTime.Now but return it in the integer style it is stored in.
Ross
Not sure this is what you are trying for, but I use this in a BAQ :
Ice.StringTime(RMAHead.ChangeTime,  'HH:MM:SS')
Brenda
Sent: Monday, February 29, 2016 11:53 AM
Subject: [Vantage] Time Integer
E10.1
Ross
