The Time Phased Inquiry screen (2022.2.12) has a field for “Attribute Set”… but it is greyed out (even on part numbers where Attribute Sets are defined) the Field Help shows no data field bound to it. Is there anyone who is able to use these fields and what are the requirements to do so? Does the Planning MRP checkbox need to be selected on the Attribute Class for it to be enabled?
I don’t have an answer for you, just an assumption.
If you look at Part Entry, there is an Advanced Planning screen that appears to allow you to set mins and other stuff by attribute set. But there is no way to actually create a record for it. I believe that they are still fleshing out AUOM and there are some things that are seen in the system but not fully developed yet.
