Time Phased Blank Title 60326
Time Phase Inquiry uses temporary data tables populated on the fly by the Adapter when a Part is loaded into the Form.
Short of buying the SDK and creating your own variant of it, changing the sort sequence is not likely achievable.
It may be possible to set up an excel workbook to utilize Time Phase's xml file. Once in excel, you could re-sort anyway you felt appropriate.
I've never tried this, but that is one of the benefits of .NET (the xml behind all forms can be used by other appropriate apps).
If anyone has experience with this, please share.
Rob Brown
Versa Products
----- Original Message ----
Sent: Wednesday, October 31, 2007 3:26:41 PM
Subject: RE: [Vantage] Time Phased
Are you talking about the time phased report? I don't see a way to change
the sort on that report(?)
_____
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of
Jim Frice
Sent: Wednesday, October 31, 2007 3:13 PM
To: vantage@yahoogroups .com
Stan,
Did you change the sort by? If you use the one Job/Part/Order by they
should then appear on top of the list in the PO suggestions.
Jim
____________ _________ _________ __
From: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
[mailto:vantage@ yahoogroups <mailto:vantage% 40yahoogroups. com> .com]
On Behalf Of sarah.vareschi@ <mailto:sarah. vareschi% 40nypromold. com>
nypromold.com
Sent: Wednesday, October 31, 2007 1:59 PM
To: vantage@yahoogroups <mailto:vantage% 40yahoogroups. com> .com
Yes, we buy almost everything direct to a job and almost
everything is
unique so not added to our part master. Our purchasers run the
"generate suggestions" a couple times a day and order anything
new. In
ours, it definitely includes non part master parts.
<mailto:vantage% 40yahoogroups. com> ] On
Behalf
Of Stan Chmura
Sent: Wednesday, October 31, 2007 2:54 PM
Thanks for the response! I don't think the generate suggestions
function is
used routinely, but I tried that to see and it didn't seem to
show the
non
part master parts. Do you purchase parts for jobs only that are
not
added
to your part master?
_____
Behalf
Of
sarah.vareschi@ <mailto:sarah. vareschi% 40nypromold. com> nypromold.com
Sent: Wednesday, October 31, 2007 2:34 PM
Do your purchasers use the Purchasing suggestions (Generate
suggestions) ? We use these and seems to be all we need, but then
again,
we have very little we actually stock so it may not apply if you
have a
lot of stocked items as well.
.com
.com] On
Behalf
Of stanchmura
Sent: Wednesday, October 31, 2007 2:29 PM
Subject: [Vantage] Time Phased
I am trying to determine a way to alert purchasing when there is
something required only for a job. i.e. the material is
purchased
only for a "one-time" job as a "Purchase Direct" material line,
and
therefore is not added to the part master. Typically the
purchasing
agent will run the time phase with the "exceptions only" checked
off
to see what (part master parts) are needed to be purchased. When
a
job has a "purchase direct" material line it only shows on the
time
phase if the "exceptions only" check box is left unchecked.
Running
the report with exceptions unchecked like that shows all
material
requirements including the ones already on purchase orders. In
our
case running the report as exceptions only usually is around
50-70
pages; unchecked is well over 300 pages. The report of course is
structured around material items that exist in the part master
and
typically will have parameters associated with the inventory set
up:
below safety, below zero, etc. (That's why the purchase direct
items only show with the box unchecked. Has anyone found a way
around this, or another method for alerting Purchasing when
non-part
master parts need to be ordered for jobs?
Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must
have already linked your email address to a yahoo id to enable
access. )
(1) To access the Files Section of our Yahoo!Group for Report
Builder
http://groups. <http://groups.
<http://groups. yahoo.com/ group/vantage/ files/>
yahoo.com/group/ vantage/files/
<http://groups. <http://groups. yahoo.com/ group/vantage/ files/>
yahoo.com/group/ vantage/files/ > >
yahoo.com/group/ vantage/files/ .
<http://groups. yahoo.com/ group/vantage/ messages>
yahoo.com/group/ vantage/messages
<http://groups. <http://groups. yahoo.com/ group/vantage/ messages>
yahoo.com/group/ vantage/messages > >
http://groups. <http://groups. <http://groups. yahoo.com/ group/vantage/ links>
yahoo.com/group/ vantage/links
yahoo.com/group/ vantage/links> >
Yahoo! Groups Links
<DIV><font size="1.5" face="Bookman Old
Style">_____ _________ _________ _________ _________ _________ ________
This email may contain material that is confidential, privileged
and/or
attorney work product for the sole use of the intended
recipient. Any
review, reliance or distribution by others or forwarding without
express
permission is strictly prohibited. If you are not the intended
recipient,
please contact the sender and delete all copies.
____________ _________ _________ _________ _________ _________ _<DIV><FONT>
must
access. )
Builder
yahoo.com/group/ vantage/files/ .>
Yahoo! Groups Links
and/or attorney work product for the sole use of the intended recipient.
Any review, reliance or distribution by others or forwarding without
express permission is strictly prohibited. If you are not the intended
recipient, please contact the sender and delete all copies.
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
something required only for a job. i.e. the material is purchased
only for a "one-time" job as a "Purchase Direct" material line, and
therefore is not added to the part master. Typically the purchasing
agent will run the time phase with the "exceptions only" checked off
to see what (part master parts) are needed to be purchased. When a
job has a "purchase direct" material line it only shows on the time
phase if the "exceptions only" check box is left unchecked. Running
the report with exceptions unchecked like that shows all material
requirements including the ones already on purchase orders. In our
case running the report as exceptions only usually is around 50-70
structured around material items that exist in the part master and
typically will have parameters associated with the inventory set up:
around this, or another method for alerting Purchasing when non-part
suggestions)? We use these and seems to be all we need, but then again,
we have very little we actually stock so it may not apply if you have a
Of stanchmura
Yahoo! Groups Links
<DIV><font size="1.5" face="Bookman Old Style">__________________________________________________________________________________________________________________
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
__________________________________________________________________________________________________________________<DIV><FONT>
Thanks for the response! I don't think the generate suggestions function is
used routinely, but I tried that to see and it didn't seem to show the non
part master parts. Do you purchase parts for jobs only that are not added
_____
sarah.vareschi@...
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of stanchmura
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
http://groups. <http://groups.yahoo.com/group/vantage/files/>
http://groups. <http://groups.yahoo.com/group/vantage/messages>
http://groups. <http://groups.yahoo.com/group/vantage/links>
Yahoo! Groups Links
Yes, we buy almost everything direct to a job and almost everything is
"generate suggestions" a couple times a day and order anything new. In
Of Stan Chmura
function is
non
added
_____
Of
sarah.vareschi@...
Behalf
Of stanchmura
Yahoo! Groups Links
recipient,
Yahoo! Groups Links
Stan,
Jim
On Behalf Of sarah.vareschi@...
everything is
new. In
Behalf
Of Stan Chmura
function is
show the
non
not
added
_____
Behalf
Of
sarah.vareschi@...
<mailto:sarah.vareschi%40nypromold.com>
again,
have a
.com
.com] On
Behalf
Of stanchmura
purchased
and
purchasing
off
a
time
Running
material
our
50-70
and
up:
non-part
must
access. )
Builder
<http://groups.yahoo.com/group/vantage/files/> >
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/links> >
Yahoo! Groups Links
and/or
recipient. Any
express
recipient,
must
access. )
Builder
Yahoo! Groups Links
_____
Jim Frice
Stan,
Jim
On Behalf Of sarah.vareschi@ <mailto:sarah.vareschi%40nypromold.com>
nypromold.com
everything is
new. In
Behalf
Of Stan Chmura
function is
show the
non
not
added
_____
Behalf
Of
sarah.vareschi@ <mailto:sarah.vareschi%40nypromold.com> nypromold.com
again,
have a
.com
.com] On
Behalf
Of stanchmura
purchased
and
purchasing
off
a
time
Running
material
our
50-70
and
up:
non-part
must
access. )
Builder
<http://groups. <http://groups.yahoo.com/group/vantage/files/>
<http://groups. <http://groups.yahoo.com/group/vantage/messages>
http://groups. <http://groups. <http://groups.yahoo.com/group/vantage/links>
Yahoo! Groups Links
and/or
recipient. Any
express
recipient,
must
access. )
Builder
Yahoo! Groups Links
Mine do not show unless I run the report with the "Exceptions Only"
unchecked. The difference for us is that unchecked it shows everything
including things that are already on order. So the Purchasing agent runs
the report with the box checked so only the stuff that hasn't been ordered
yet and does not meet the inventory set up criteria (below safety, below
zero, etc.) appears.
_____
sarah.vareschi@...
Sent: Wednesday, October 31, 2007 2:59 PM
Behalf
Of Stan Chmura
function is
non
added
_____
Behalf
Of
Behalf
Of stanchmura
Yahoo! Groups Links
recipient,
Yahoo! Groups Links
I am talking about the PO suggestions. When you run the "generate
suggestions" it doesn't give an option (on 5.2 anyway) and just runs for
everything. Then, when you go into PO entry and look at the "new" po
suggestions, it shows everything that the system thinks needs a new po.
Any non part master part added a job should show up here as needing a
po. You can sort this list by job#.
Of Stan Chmura
Sent: Wednesday, October 31, 2007 3:28 PM
runs
ordered
_____
Of
sarah.vareschi@...
Behalf
Of Stan Chmura
function is
non
added
_____
Behalf
Of
Behalf
Of stanchmura
Yahoo! Groups Links
recipient,
Yahoo! Groups Links
recipient,
Yahoo! Groups Links
