Jim,
I am told that the 2572 shows up, but the purchased 2572-1 does not.
And that is the problem. We are running out of purchased, stocked,
raw materials.
Then Time phased is run with the "BOTH" and "BOTH" for purchased and
stocked items.
I will be out of town starting later today, so you may see this
thread picked up my one of my co-workers, mheffernan@...
Thanks for you time!!
Andrew
raw materials.
stocked items.
Andrew
--- In vantage@y..., "Jim Frice" <Jim.Frice@f...> wrote:
> Andrew,
> Are they running the time phase for both manufacture and purchased?
2572-1
> you said is set up as a purchased part. If 2572 is a subassembly
then it is
> assumed it will be made therefore no suggestion on the time phase
will be
> created. The subassembly needs to be pulled from stock if you want
it to
> show on the time phase. You shouldn't have the 2572 listed as an
assembly
> and as a material because that means you should be producing one
and issuing
> one. Is the 2572 showing up on the time phase at all?
> > -----Original Message-----
> > From: acretors@c... [mailto:acretors@c...]
> > Sent: Friday, January 26, 2001 2:47 PM
> > To: vantage@y...
> > Subject: [Vantage] Re: Time Phased report
> > Jim,
> > These are all great questions, let's see what Vantage shows:
> > 1. On the BOM, 2572 is a subassembly of the top assembly 7700.
2572-1
> > is a material of subassembly 2572. On the job however, 2572 is a
> > material to the top assemply 7700... Hmm Why is that? Is that ok?
> > 2. Looking at the material pn 2572 on a job, it is not
backflushed,
> > purchased direct, or manufactured direct (none of these check
boxes
> > are checked)
> > I went into the training database, and created a job for 7700 to
be
> > built for stock. 2572 was pulled in as a material. Looking at the
> > routing for 7700, 2572 has Pull as Assembly NOT checked, and View
as
> > Assembly CHECKED.
> > I hope this gives you enough info to point me further into the
right
> > direction...
> > My many thanks in advance!!
> > Andrew
> > > Andrew,
> > > Is the assembly 2572 a material on the job for 7700 or an
> > assembly? Is the
> > > assembly part number 2572 being produced or pulled from stock?
How
> > is the
> > > material 2572-1 linked to the assembly 2572? Is it backflushed
or
> > purchased?
> > > > Sent: Friday, January 26, 2001 12:39 PM
> > > > To: vantage@y...
> > > > Subject: [Vantage] Time Phased report
> > > > To all,
> > > > I have a stocked, manufactured, part; part number 7700. It
has an
> > > > assembly, part number 2572. This assembly has a purchased
> > material,
> > > > part number 2572-1. When a production order is entered for the
> > 7700,
> > > > we do not see the demand on the material 2572-1. Why is this?
The
> > > > assembly is a stocked item, as is the material... What should
I
> > look
> > > > for?
> > > > Any help is MUCH appreciated. Purchasing is pulling their hair
> > out!
> > > > Andrew
> > > > To unsubscribe from this group, send an email to:
> > > > vantage-unsubscribe@egroups.com
