Ah, OK. "That" code. :-) Yeah, I don't have the SDK.
Yea, we use the net time statement in a bat file on many client
workstations that are finicky with syncing with the domain.
Of Podlin, Michael
Sent: Friday, April 01, 2011 5:05 PM
Subject: RE: [Vantage] Time sync
It's in the compiled Progress program code itself. I don't own Vantage
source code, so I can't tell if it is in there or not. If its not
(which I'm led to believe from past experience), then the time stamps
are based upon the workstation itself and not the server.
What you might try as a possible workaround to keep the workstations
close in sync with the server time, is create a routine on the
workstations that does a NET TIME \\vantageserver /SET command and sync
the workstation's time to the vantage server. Then just schedule it as
a reoccurring task once to several times a day. That should keep the
times close to in sync.
Michael Podlin
Network Administrator
V-S Industries, Inc.
900 S. Chaddick Dr.
Wheeling, IL 60090
847-520-1800 x207
Fax 847-520-0269
Michael.Podlin@... <mailto:Michael.Podlin%40v-s.com>
Behalf
Of Vic Drecchio
Sent: Friday, April 01, 2011 3:46 PM
Michael, curious, where in "what" code is this set? I checked the
obvious .mfgsys files in \Config but I don't see it.
Behalf
Of Podlin, Michael
Sent: Friday, April 01, 2011 1:47 PM
Actually there is a TIME-SOURCE attribute for the SESSION, the default
is the client's workstation. If you want to use the time from the
server you have to set the TIME-SOURCE attribute in the code to
something like this: ASSIGN SESSION:TIME-SOURCE = "mfgsys"
Not sure what is coded into Vantage........ I had to add this line in a
lot of my code so that all time stamp entries from any pc workstation
all were the same time as the Vantage server.
Michael Podlin
900 S. Chaddick Dr.
Wheeling, IL 60090
847-520-1800 x207
Fax 847-520-0269
Please consider the environment.
Do you really need to print this email?
Behalf
Of Chris Crosta
Sent: Friday, April 01, 2011 11:02 AM
Subject: [Vantage] Time sync
How does vantage keep track of time? I thought the Vantage clock was
synced to the server but I have recently seen discrepancies of up to a
minute during the day. We are on version 6.10.533
Chris
Of Podlin, Michael
Michael Podlin
900 S. Chaddick Dr.
Wheeling, IL 60090
847-520-1800 x207
Fax 847-520-0269
Behalf
Of Vic Drecchio
Behalf
Of Podlin, Michael
Michael Podlin
900 S. Chaddick Dr.
Wheeling, IL 60090
847-520-1800 x207
Fax 847-520-0269
Behalf
Of Chris Crosta
Chris
