I am trying to use time approval and I have set it up so each supervisor can approve employees times. If that supervisor is not at work how do I get that time sent to someone else for approval? I tried making the Director able to enter and change all time for employees but this doesnt give him access to approve it.
If i set up the workflow with my supervisor then her supervisor it needs both their signatures for approval and I ideally want it to need either/ or.
In the Task setup, do you have the “Any Approver” option enabled?
“Multiple persons can be assigned to an approver role. If Any Approver is selected, only one of these persons must complete the approval task for the task and milestone to be marked complete. If Any Approver is cleared, all persons assigned to the role must complete the task for the milestone to be marked completed. Used for time and expense transactions.”
Thank you so much for the reply and that has fixed that issue. My next issue is that I wanted workflow to work per department but it appears like the one set up in site config in the overriding workflow. Any idea how I work around that? TIA
