To Warehouse cannot be set without Advanced Material Management License. To Bin cannot be set without Advanced Material Management Licenses
We got the following error message when issuing material.
To Warehouse cannot be set without Advanced Material Management License. To Bin cannot be set without Advanced Material Management Licenses.
We used to have the AMM licences and but deactivated the license a few month ago. We got the similar issue three month ago and fixed it by a solution (cleaned warehouse fields). But the solution doesn’t work ago.
Anyone knows how to fix it? Thanks.
I’ve heard from multiple sources, that “once you turn on AMM, you cannot turn it off”. I don’t know all of the details, but you might be stuck with AMM.
Thanks, Banderson.
Below is the error I got it now and three months ago.
Open all of your Resource Groups, uncheck the Location box at the Group level and the individual Resource level.
Thank you! The Location check box fixed the issue for us.
