Tool files
We use "Tooling Kits" which are simply Subassemblies with it's
own BOM. I also have two operations in the Tool Kit Subassembly. Op
10 Perishable Tools, and Op 20 Durable Tools. Then the tooling
"materials" are linked to which sequence operation number for which they
belong, tooling holders and collets,etc. are linked to the op 20 Durable
Tools, drills, blades, inserts, form tools , etc., are linked to op 10
Perishable Tools.
When it is a subassembly, then it can also be schedule because
the parent part/job is scheduled. It works rather nicely...
Rick Joslin
V-S Industries
Hello Everyone:
Please let me know if you have a procedure that addresses the following manufacturing issue. Many of our manufacturing operations require specific tools, dies and fixtures to perform. These various tools have tool numbers which are listed in the comments of each operation. These tools are cataloged using a paper file which lists all tool specifications but does not indicate what part/operations they are used on. We would like to ues a tool file within Vantage if possible, similar to Work Center Master that would allow us to store and maintain various tool data but more importantly would allow us to do a "Tool Where Used". Currently, we are relying on our set-up personnel's memory should we wish to alter a tool for a new part requirement.
Thank You,
We are in the same boat but with a few tweaks it has never been critical enough to be an issue. But in discussing your questions with our process engineers I can see where there would be definite benefits to having a "tooling resource" capability.
First, for the vast majority of our tooling there is a 1-for-1 relation to the specific part so we have tooling sets identified with a tool number. This number (as it happens starts with the letter A on all of them so they are called "A numbers" here) is the first part of the part description. This also makes it the search word in a part lookup. We use customer part numbers as our selling part but internally the A number is our own part number because of the association with the tool set. Tools are numbered with little brass or aluminum plates with the number and if there are multiple stage tools for different operations that are -1, -2, -3, etc... and the setup people know which to grab for each oper sequence and they are all stored together on shelves for a-number ranges (like a library).
We also have the situation where we "borrow" tools. In this case the A-number is noted (as you suggest) in the oper comments. Often we have a tool used on one part that "fits" another application (if the sales engineer is smart that day they think of it and build it in to the pricing). To track usage of borrowed tools we maintain a card file by A-number. If we wanted a Vantage report for "where used " then a standardized commenting procedure would work (with RB anyway, Crystal chokes on memo fields). The key would be 100% compliance with the recording scheme so it can be parsed out of the string.
Finally we have stock tooling. This has no identification like a tool number but rather is stored and referenced by attributes (radius, depth, dimensions, etc...). This is especially true in the case of simple bending tools for press brake operations. These are referenced in the oper comments as with borrowed tools. But the process engineers thought we could "stock" this tooling as a material to be used a job with a qty per of .000001 and then issue qty 1 to it. The remainder to be returned to "inventory". I have seen this approach discussed a few times but am not sure what impact this would have on our accounting people or job costs. I would for sure mean ignoring a lot of very small numbers here and there. On the other hand they though the "usage" (with some playing with decimal places) could indicate stock tool usage and recommend tool replacement or repair cycles. At the very least if a tool broke you could look and see what parts (or even scheduled jobs) would be impacted via material "where used" reports.
Bottom line is we think the issues could be addressed with Vantage as it now is but clumsily. A facility for non-consumable interchangeable resources (like tooling) would certainly be handy. It would have to wait for beyond 8.0 (even past 8.x all the way to 9). In the mean time there are some things at 8.0 (when it is usable) that could make it a snap to do via user fields and form customizations at the BOM oper level. If this is so it might never become a Vantage, table based, capability.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Robert Christian
Sent: Thursday, November 17, 2005 9:20 AM
Subject: [Vantage] TOOL FILES
Hello Everyone:
Thank You,
SPONSORED LINKS
Manufacturing <http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software Membership <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software Database <http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
Pda <http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software Database <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software Database <http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufacturing+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pda+database+software&w5=Database+management+software&w6=Database+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
One option is to list your tools and fixtures in the part master at a zero
cost, in a "tooling warehouse", with a tooling part class. Then call them
out as materials on the manufacturing BOM's, associated to the operation
that uses them, with a .00001 fixed quantity (negligible quantity so no
issuing and receiving). This also allows attaching tool drawings or
specifications to the tool part numbers, and using the where-used feature.
It's not perfect, but it works OK.
In 8.0, you can still do this, but you have the alternative option of
listing your tools as resources. I believe this is the direction we will
eventually head, but for now we continue to work with them as I describe
above.
Amy O'Malley
Manufacturing Process Engineer
Synovis Interventional Solutions
v. 8.00.804
On 17 Nov 2005, Robert Christian wrote:
> Hello Everyone:
specific
numbers
cataloged
indicate
allow us
us
requirement.
> Thank You,
Thanks Todd
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Thursday, November 17, 2005 11:18 AM
Subject: RE: [Vantage] TOOL FILES
out of the string.
> -Todd C.
Of Robert Christian
> Hello Everyone:
requirement.
> Thank You,
> SPONSORED LINKS
> Manufacturing
Database
> Pda
Database
> _____
> YAHOO! GROUPS LINKS
the web.
> _____
> Yahoo! Groups Links
