Do you use the material salvage ability at all? This is the only way I have
found to issue a die then return it leaving some cost. Of course you have to
calculate the costs manually.
Patrick J. Winter
Information Services Manager
sSc Specialty Screw Corporation
Vantage 4.00.901
hiattmfg@...]
Sent: Tuesday, December 26, 2000 05:00 PM
To:
vantage@egroups.com
Subject: Re: [Vantage] Tool Tracking
Patrick,
We have a similar situation with the 5 decimal problem. There are only 2
ways I have found to get around this:
1. Set up BOM's as a "carton quantity" rather than single pieces. For
example, if the part is packaged 1000 per carton, set up the BOM to require
1000 parts, 1 carton, and 1 label. Then there is nothing under "1" required.
The bad part about this is then a 50,000 piece order is really for 50
cartons (not a feasable solution for made to order parts). Worked fine for
us with a made to stock part.
2. Job creator must round these off. This is the solution we use now. The
person who creates the jobs must be heads up enough to make the requirement
a fixed 4 units for a 2,000,000 piece order - even though the BOM suggests
20 when rounded to .00001 rather than .000002.
Hope that helps,
John Mueske
Hiatt Manufactuirng, Inc.
SBS 4.5 - Vantage 3.00.632
----- Original Message -----
To: Vantage User Group on Onelist (E-mail)
Sent: Tuesday, December 26, 2000 4:15 PM
Subject: [Vantage] Tool Tracking
Problem:
I have roll thread dies that can run 500,000 pcs.
I list them as a BOM item but qty per is only 5 decimal places.
If my lot size is 500,000 qty per needs to be .000002
Does anyone have a work around for the 5 decimal limitation in the
quantity
per field when creating a BOM?
Patrick J. Winter
Vantage 4.00.901
eGroups Sponsor
(Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
