Total hours required to build a part including labor hours and
Thanks Todd,
That will help me.
Nam
--- In vantage@yahoogroups.com, "Todd Caughey" <caugheyt@h...> wrote:
> Then move time will be the tricky part and pretty specific to your
environment. Things like work cells (or not) and outside processing
etc... Also sounds like a "perfect world" sort thing based
estimated times. The estimates in Job Assembly table at level zero
(adding in lower levels) would be OK for the actual operations but
the "inter-operation" movements and lag times might require "factor"
type estimates. Also is this for one part (as in the first part from
start to finish) or for whole job (first part in to last part out)?
Then the method of movement (continuous or batch) will play a huge
role in the total time - especially if there is subcontract operation
(s) involvement where typically a batch wold "go outside".
> There are some MoveDue date/times used by scheduling but I am not
sure if subtracting these to add up eleapsed "scheduled moves" would
really work and then there is the issue of intended "idle" time in
movements waiting for next operation's WC/machine to finish some
other part.
> Sorry to add more complexity but defining all the issues will help
resolve the method.
> -Todd C.
> -----Original Message-----
> From: progress92000 [mailto:nvong@m...]
> Sent: Wednesday, August 24, 2005 9:00 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: total hours required to build a part
including labor hours and movetime
> Thanks Todd, unfortunately it is the new part so such labor
> transactions.
> Nam
wrote:
> > Date of First LaborDtl Clock-in (use MInimum function) minus
Date
> of Last LaborDtl Clock-out (Maximum) times 24 plus the added up
clock-
> in times minus clockouts on the last day. At least that's where I
> wouild start. Probably reported as hours.decimal hour unless jobs
> run many days in which case forget the X 24 part and just use the #
> of days.
> > -Todd C.
> > Sent: Wednesday, August 24, 2005 8:47 AM
> > Subject: [Vantage] total hours required to build a part including
> > Hi Group,
> > I want to make a report to show total hours required to build a
> part
> > including labor hours and movetime.
> > I could find such report in the Vantage. Any idea where I should
> start?
> > Thanks in advance,
> > Nam
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must have already linked your email address to a yahoo id to enable
> access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and Crystal Reports and other 'goodies', please goto:
> > (3) To view links to Vendors that provide Vantage services goto:
> > SPONSORED LINKS
> > Technical < http://groups.yahoo.com/gads?
t=ms&k=Technical+support&w1=Technical+support&w2=Vantage&w3=Database&w
4=Database+management+software&w5=Membership+database+software&w6=Chur
> ch+database+software&c=6&s=148&.sig=D_JdAFeHAoeH6OugOKk1Yg> support
> Vantage < http://groups.yahoo.com/gads?
t=ms&k=Vantage&w1=Technical+support&w2=Vantage&w3=Database&w4=Database
+management+software&w5=Membership+database+software&w6=Church+databas
> e+software&c=6&s=148&.sig=8zJYQk3edGWFMUVgup9jKw> Database
t=ms&k=Database&w1=Technical+support&w2=Vantage&w3=Database&w4=Databas
e+management+software&w5=Membership+database+software&w6=Church+databa
> se+software&c=6&s=148&.sig=PnI9nhHllVsjEbHxRXs1IQ>
> > Database < http://groups.yahoo.com/gads?
t=ms&k=Database+management+software&w1=Technical+support&w2=Vantage&w3
=Database&w4=Database+management+software&w5=Membership+database+softw
> are&w6=Church+database+software&c=6&s=148&.sig=fKR9gtx-Yh-u9MWSh0_-
> hA> management software Membership
t=ms&k=Membership+database+software&w1=Technical+support&w2=Vantage&w3
are&w6=Church+database+software&c=6&s=148&.sig=Nu4StMQZ8LT26M5TzRGQlg>
> database software Church < http://groups.yahoo.com/gads?
t=ms&k=Church+database+software&w1=Technical+support&w2=Vantage&w3=Dat
abase&w4=Database+management+software&w5=Membership+database+software&
> w6=Church+database+software&c=6&s=148&.sig=UAiQi3Ftbp7Qnq6ys_yZxg>
> database software
> > _____
> > YAHOO! GROUPS LINKS
> > * Visit your group " vantage
> < http://groups.yahoo.com/group/vantage> " on the web.
> > * To unsubscribe from this group, send an email to:
> > vantage-unsubscribe@yahoogroups.com <mailto:vantage-
> unsubscribe@yahoogroups.com?subject=Unsubscribe>
> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms
of
> Service < http://docs.yahoo.com/info/terms/> .
> > _____
access. )
> SPONSORED LINKS
> Technical <http://groups.yahoo.com/gads?
Vantage <http://groups.yahoo.com/gads?
> Database <http://groups.yahoo.com/gads?
database software Church <http://groups.yahoo.com/gads?
database software
> _____
> YAHOO! GROUPS LINKS
<http://groups.yahoo.com/group/vantage> " on the web.
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
> _____
Hi Group,
I want to make a report to show total hours required to build a part
I could find such report in the Vantage. Any idea where I should start?
Thanks in advance,
Nam
Date of First LaborDtl Clock-in (use MInimum function) minus Date of Last LaborDtl Clock-out (Maximum) times 24 plus the added up clock-in times minus clockouts on the last day. At least that's where I wouild start. Probably reported as hours.decimal hour unless jobs run many days in which case forget the X 24 part and just use the # of days.
-Todd C.
Subject: [Vantage] total hours required to build a part including labor hours and movetime
Hi Group,
Thanks in advance,
Nam
SPONSORED LINKS
Technical <http://groups.yahoo.com/gads?t=ms&k=Technical+support&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=D_JdAFeHAoeH6OugOKk1Yg> support Vantage <http://groups.yahoo.com/gads?t=ms&k=Vantage&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=8zJYQk3edGWFMUVgup9jKw> Database <http://groups.yahoo.com/gads?t=ms&k=Database&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=PnI9nhHllVsjEbHxRXs1IQ>
Database <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=fKR9gtx-Yh-u9MWSh0_-hA> management software Membership <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=Nu4StMQZ8LT26M5TzRGQlg> database software Church <http://groups.yahoo.com/gads?t=ms&k=Church+database+software&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=UAiQi3Ftbp7Qnq6ys_yZxg> database software
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
transactions.
Nam
of days.
> -Todd C.
> Hi Group,
part
start?
> Thanks in advance,
> Nam
access. )
> SPONSORED LINKS
database software
> _____
> YAHOO! GROUPS LINKS
> _____
Ooops. Last day...just use the clock-out time (time since midnight) of the last (Max) LaborDtl. No need to add up times since you need move time too.
-Todd C.
Sent: Wednesday, August 24, 2005 8:56 AM
Subject: RE: [Vantage] total hours required to build a part including labor hours and movetime
-Todd C.
Hi Group,
Thanks in advance,
Nam
SPONSORED LINKS
Technical < http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Technical+support&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=D_JdAFeHAoeH6OugOKk1Yg> &k=Technical+support&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=D_JdAFeHAoeH6OugOKk1Yg> support Vantage < http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Vantage&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=8zJYQk3edGWFMUVgup9jKw> &k=Vantage&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=8zJYQk3edGWFMUVgup9jKw> Database < http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=PnI9nhHllVsjEbHxRXs1IQ> &k=Database&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=PnI9nhHllVsjEbHxRXs1IQ>
Database < http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=fKR9gtx-Yh-u9MWSh0_-hA> &k=Database+management+software&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=fKR9gtx-Yh-u9MWSh0_-hA> management software Membership < http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=Nu4StMQZ8LT26M5TzRGQlg> &k=Membership+database+software&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=Nu4StMQZ8LT26M5TzRGQlg> database software Church < http://groups.yahoo.com/gads?t=ms <http://groups.yahoo.com/gads?t=ms&k=Church+database+software&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=UAiQi3Ftbp7Qnq6ys_yZxg> &k=Church+database+software&w1=Technical+support&w2=Vantage&w3=Database&w4=Database+management+software&w5=Membership+database+software&w6=Church+database+software&c=6&s=148&.sig=UAiQi3Ftbp7Qnq6ys_yZxg> database software
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage < http://groups.yahoo.com/group/vantage> " on the web.
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service < http://docs.yahoo.com/info/terms/> .
_____
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
Then move time will be the tricky part and pretty specific to your environment. Things like work cells (or not) and outside processing etc... Also sounds like a "perfect world" sort thing based estimated times. The estimates in Job Assembly table at level zero (adding in lower levels) would be OK for the actual operations but the "inter-operation" movements and lag times might require "factor" type estimates. Also is this for one part (as in the first part from start to finish) or for whole job (first part in to last part out)? Then the method of movement (continuous or batch) will play a huge role in the total time - especially if there is subcontract operation(s) involvement where typically a batch wold "go outside".
There are some MoveDue date/times used by scheduling but I am not sure if subtracting these to add up eleapsed "scheduled moves" would really work and then there is the issue of intended "idle" time in movements waiting for next operation's WC/machine to finish some other part.
Sorry to add more complexity but defining all the issues will help resolve the method.
-Todd C.
Subject: [Vantage] Re: total hours required to build a part including labor hours and movetime
transactions.
Nam
of days.
> -Todd C.
> Hi Group,
part
start?
> Thanks in advance,
> Nam
access. )
> SPONSORED LINKS
database software
> _____
> YAHOO! GROUPS LINKS
> _____
SPONSORED LINKS
_____
YAHOO! GROUPS LINKS
_____
