Track Demensions
We have not used dimensions since version 5.2 some time ago but when I turned it off I had to go into inventory quantity adjustments and set all the dimension quantities for each part we were using dimensions on to zero. I could then turn off the dimensions function.
John Walter | Group IS Manager | Hufcor Pty Ltd
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jonathan Lang
Sent: Thursday, 8 January 2009 8:39 AM
Subject: [Vantage] Track Demensions
I have a problem with a part that was checked Track Demensions. I cannot uncheck the Track Demension's box because it tells me the following:
Track Dimension cannot be turned OFF because there is at least one PartTran record with a dimension defined.
Anyone have any ideas on how to remove this?
Thanks all,
Jonathan Lang
Oil Rite Corporation
Sr. Network Administrator
Ph: (920) 682-6173 Ext: 126
Fax: (920) 682-7699
Â
Â
Â
Thanks all,
Jonathan LangÂ
Fax: (920) 682-7699
Â
