Track PO Approval Chain
We would like to track the multi-level approval chain for POs, not just the last one, which is all you get in POApvMsg - each record overwrites the previous one.
The table does not have a change log, so the usual change log data directive will not work. It seems very odd that the entire approval chain is not captured somewhere, but I cannot find it.
So…
  1. Is this data somewhere? I thought I saw a reference to it being in PO tracker, but did not see it.
  2. What is the best way to go about this? Do we need a UD table?
Thanks.
You should be able to add a change log on that table. You will have to create your own data viewer for it.
Thanks. I used an updatable BAQ.
