Hello,
Is anyone else having issues when using trackers in a dashboard when set as a Dashboard-Assembly Program Type?
I have a dashboard that is using a tracker (based on the part number) to filter two other queries. This works without issue in the Dashboard Developer.
Once I create the Menu Item and set the Program Type to Dashboard-Assembly the two queries that should be filtered are not running. The query with the tracker is the only query that will return data.
I changed the Program Type to Dashboard-Runtime and now the tracker and queries run without issue.
Is this a common issue with Dashboard-Assembly or is there a way to resolve this to gain the advantages of Dashboard-Assembly?
