Thanks it all makes sense but at this point it won't help me find a log to prove who did it and when. I guess that I will have to start setting up some change log filters now for in the future. Thanks for both of your help.
--- In vantage@yahoogroups.com, Manasa Reddy <manasa@...> wrote:
> Vic is right in the setup, but what he didn't mention is that it will trace activity from the point you create the log. You will not see past history if you did not start the log in the past.
> Hope that made sense.
> M. Manasa Reddy
> manasa@...<mailto:manasa@...>
> 630.806.2000 x1515
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
> Sent: Wednesday, August 15, 2012 12:45 PM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Re: Tracking user activity
> Change Log is not activated on any tables out-of-the-box. You need to
> configure which tables get tracked.
> You can see the Change Log on most screens. For example, in Part
> Maintenance go to Actions (on the menu bar) and then down to Change Log.
> You must have "something" in context for this to work. In this case, open
> any Part Number and go to Actions/ChangeLog as if you were attempting to get
> some info about it. The Change Log Viewer pops open for that Part.
> To implement Change Logs, you need to set up BAMs on each of the tables that
> you wish to track. Biz Activity Manager (BAM) is found under System Mgmt /
> Utilities. Once opened, choose a table to track.. like "Part". Then select
> the fields you wish to monitor. maybe TypeCode, CostMethod, TrackLots,
> ProdCode, ClassID. Then, on the Action tab, check "Create Log" and then
> save. Done.
> To test, make a change to one of those fields you selected above in Part.
> Then immediately open the ChangeLog in Part Maint on that Part Number.
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
> dhilliard35
> Sent: Wednesday, August 15, 2012 1:36 PM
> Subject: [Vantage] Re: Tracking user activity
> Thanks for that info. Can you tell me where Change Log is so I can browse
> through that?
> Thanks
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> , "Vic
> Drecchio" <vic.drecchio@<mailto:vic.drecchio@>> wrote:
> > Change Log will show you additions and changes to data; but if 9.x is the
> > same as 8.x, the Change Log will NOT show you Deletions, very
> unfortunately.
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
> Behalf Of
> > dhilliard35
> > Sent: Wednesday, August 15, 2012 1:21 PM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
> > Subject: [Vantage] Tracking user activity
> > I have been working on implementation of a new Epicor system and I am
> > looking for a way to find out what a particular user has done in the past
> on
> > our Pilot system. Specifically I want to know if a user deleted all
> > employees from the system. So far I have not been able to find anything in
> > the system that would help me accomplish this.
> > No virus found in this message.
> > Checked by AVG - www.avg.com<http://www.avg.com>
> > Version: 2012.0.2197 / Virus Database: 2437/5201 - Release Date: 08/14/12
