Training Database 5.0
Terry,
I tried both. Neither made a difference with my training database. But I was
successful using procontrol to start and stop the the live database without using the
Progress Explorer. But the only problem I saw was Progress explorer did not
recognize it as running when I started it with Procontrol. But I was able to run
Vantage (opps sorry Emanufacturing) from a client.
Did he mention any problems with using procontrol? I agree with you I would rather
use procontrol than progress explorer.
Dina
Vamco International, Inc.
Terry Williams wrote:
> Dina:
> Just got back from the NY/PA users' group meeting. Asked Dave, the Epicor
> rep there if I could use procontrol to start/stop the 5.0 database instead
> of Progress Explorer per installation instructions. According to him, "No,
> you have to use Progress Explorer". I asked this question because,
> personally I like procontrol - I understand it, it's less cumbersome to use
> than Pro Explorer, etc.
> Are you using the procontrol to start/stop 5.? I've planned on trying this,
> just haven't gotten to it yet.
> Terry L. Williams I.S. Manager Chipsco, Inc. 9936 Liberty St. Ext.
> Meadville, PA 16335 814-333-6331 x236 fax: 814-337-2548 tlw@...
> www.chipsco.com
> -----Original Message-----
> From: Dina Hieber [mailto:dhieber@...]
> Sent: Wednesday, January 24, 2001 11:44 AM
> To: vantage@onelist.com
> Subject: [Vantage] Training Database 5.0
> We installed Vantage 5.0 on a "dummy server". The training database is
> giving me an error when I try to start it from procontrol. "Can not
> find (.lk) file.
> We were training someone which may have made a mistake. I was going to
> do a back up from 4.0 training and restore it to 5.0 training but we
> removed 4.0 already from this computer.
> Any ideas?
> Thanks,
> Dina
> To unsubscribe from this group, send an email to:
> vantage-unsubscribe@egroups.com
Wayne,
Excuse my ignorance - but since my vantage 5.0 live is running okay, it is just
the training database. I am going to assume I would use:
d:\epic50\progress\bin\prostrct repair vntgtrn
Thank you!!!
Dina
> >find (.lk) file.
> Usually happens if the database files have been moved to a different
> directory using windoze tools. This is from Epicor's site; had it handy
> from Monday....
> -WC
> Unable to Find .LK file (5199).
> Problem Resolution:
> If the database was copied using windows explorer, you will need to run the
> Progress utility "prostrct repair".
> The error from the NT Event Viewer will state: "Database is Copy of"
> followed by a path of the database's original location.
> How to fix:
> 1) At the NT Server, go to a MSDOS Command Prompt.
> 2) Change Directories to the folder where the copied database is.
> 3) Next, set the DLC variable. At the prompt type: set dlc=c:\epicor\progress
> 4) Again at the prompt type: c:\epicor\progress\bin\prostrct repair vantage
> 5) Once the prompt returns, type: exit
> 6) Start the database.
> Additional information:
> You can locate the V:\Vantage\Db\Vantage.st file and right mouse click
> selecting "edit". If the vantage.st file looks like this:
> b.\vantage.b1
> d "Schema Area":6,32.\vantage.d1
> Then you can either change directory into the Vantage\db folder so your are
> standing in the folder when you run "prostrct repair" or again edit the
> file to look like the second sample below. If the Vantage.st looks like
> this one, you can run the command below.
> cd c:\epicor\vantage\db
> c:\progress\bin\prostrct repair vantage
> Alternatively, you can edit the Vantage.st file to look like the following,
> giving each extent the full path of where it is now living. This is useful
> if you have multiple drives in the Server and want to have the B1 file on
> one drive and the D1 and DB on the other.
> b C:\Epicor\vantage\db
> d "Schema Area":6,32 C:\Epicor\vantage\db
> Then if the file looks like the above, run the command below:
> cd c:\epicor\progress bin
> prostrct repair c:\epicor\vantage\db\vantage
> ***As per instructions from email from Epicor, March 20, 2000***
>just
Oh... actually the 5.0 bit flew right by me. That advice applies to 4.0 &
Progress 9.0. 5 is on Progress 9.1, so I'm not 100% the command is the
same. In the past, the database file name is the same in live, training,
etc. But the directory changes. For example, 4 was "vantage" in all of
them, and training was \VntgTrn\DB\Vantage So you can either change dir
to \VntgTrn\DB\ and use .\Vantage as the database name, or give it the
full path.
If the command and directory haven't changed too much, the whole thing
might be:
d:\epic50\progress\bin\prostrct repair d:\epic50\vntgtrn\db\vantage
But it might be best just to call tech suppt.
-Wayne
Progres explorer seems like a waste of time. I used procontrol
for v5 just fine. All software has to have an "explorer" these days.
> Dina:
> www.chipsco.com
> find (.lk) file.
> Any ideas?
> Thanks,
> Dina
