Transfer Order Blank Title 74047
Is the scope too large to just use an 'honor system' organizational rule (backed up by change log traceability to 'enforce' the 'honor rule')?
If it is, then either a BAM to detect qty change or a .NET or BPM piggybacking the update method (before it executes) might be better.
If you are using user access roles in a way that would allow it (without major changes), you could just disable the appropriate update method for district plant users. (That might be the cleanest way come to think of it...)
Rob
--- On Mon, 2/9/09, Tony Hughes <thughes281@...> wrote:
Subject: Re: [Vantage] Transfer Order
Date: Monday, February 9, 2009, 12:17 PM
Next step...
I figure I will use process security to limit who can delete a TO.
To catch the qty change, would you think that preventing that in the Update method is best way?
Or am I going about this all the wrong way?
What I want is that once a Transfer order is created, the district plant cannot modify it. They would have to call the main plant to change or delete it.
____________ _________ _________ __
To: vantage@yahoogroups .com
Sent: Monday, February 9, 2009 11:01:05 AM
Deletion? You're screwed (short of looking at backups - which isn't practical.)
Qty change? Add Job Qty to your change log traced field list.
Rob
--- On Mon, 2/9/09, Tony Hughes <thughes281@ yahoo. com> wrote:
Subject: [Vantage] Transfer Order
Date: Monday, February 9, 2009, 11:56 AM
If a transfer order generates an MRP suggestion, and the suggestion is converted to a job, how would you know when someone goes in and modifies quantity on that TO line, or even deletes the line?
Rob
Next step...
Rob
