Transfer Order Shipment Error
Hello everyone,
I’ve error when I want to transfer order shipment
I got error message " The remaining amount is greater than zero and there is no FIFO cost available to consume"
I’ve check material unit cost in Part FIFO Cost and in Part Tran that material unit cost is there
I don’t know why I got this error message
I hope you can help me about my case
Thankyou
Regards,
Fara
Sounds like your FIFO layer got clobbered. Typically this happens when the transaction amount is greater than the non consumed FIFO amount.
Look into the following tables:
erp.PartFIFOTran
erp.PartFIFOCost
erp.PartTran
Hi Doug.C
Thankyou for the advice
I’ve solved this case
