Transfer order workbench
I am facing an issue with a transfer order that I created. The transfer order number is MECH000188. When I checked the workbench, I couldn’t find it.
but the transfer order workbench API is showing my newly created TO.
I am new to using Epicor and am unsure what could be causing this issue. Can someone please guide me through the steps to check if the transfer order was created correctly and why it’s not showing up on the workbench? Any help is highly appreciated.
Thank you.
Is that a custom screen? I’m not familiar with it. In any case if the TO is already created why wouldn’t you look under Transfer order entry, its not a suggestion right?
Thanks for your response, can you guide If I created new TO then which form I can see newly created TO?
As I said above, Transfer order entry is where you can pull up existing transfer orders.
Ok, so when I created a new TO then how did bin assign to Part Num on the TO line?
Basically for my BAQ, I want a report that shows the TO and allocated bin of Part Nums.
Can you suggest me table name, I did not find much information in the Data Dictionary.
Go to the transfer order screen, turn on the field help, click in the fields you want to query, and see what database fields they are bound to.
Can you provide some screenshots of the steps, it will be very helpful.
“I appreciate the field help features. They have been very helpful to me.”
