I'm pretty sure of the short answer to this question, but has anyone
found a way to receive transfer orders directly into inspection? We
build and test product at our location and ship it to our sister plant.
They perform visual and sometimes electrical inspection on these prior
to stocking them. Right now they receive the transfer order material
into a separate warehouse, then transfer the good parts to the standard
warehouse after passing inspection.
Any ideas would be much appreciated.
Mark L. Knight, CPIM
Master Scheduler
Picometrix, LLC (an API company)
2925 Boardwalk
Ann Arbor, MI 48104
Phone: 734-864-5675
Fax: 734-998-3474
mknight@...
This transmission contains information belonging to Picometrix and is
confidential and/or legally privileged under all Non-Disclosure
Agreements in place between Picometrix and the recipient. The
information is intended for the use of the individual or entity named
above. If you are not the intended recipient, you are hereby notified
that disclosing, distributing or copying this information is strictly
prohibited. If you have received this email in error, please contact the
sender named above.
Master Scheduler
2925 Boardwalk
Ann Arbor, MI 48104
Phone: 734-864-5675
Fax: 734-998-3474
mknight@...
sender named above.
