We have a multi-site setup: Assembly and Fabrication. The fabrication site supplies to the assembly site. Fabrication also sells about $1M monthly externally. The Assembly site is MTO and also has a forecast in for select customers. We strictly want Fabrication to ONLY build what Assembly receives orders for from the transfer standpoint. We want to submit transfer orders to Fabrication before they create the job within the lead time on the part. The way the transfer orders are setup today do not work that way. We have export suggestions and do a bunch of math using the standard lead time on transfer parts to back date the due date into the order date. Change suggestions are also embedded into the new suggestions so very hard to follow. We have attempted to make a dashboard to help give visibility on what is needed for assy, what is on order with fab and what has a job at fab but it doesn’t give any future dates. We are about to fold and just setup the fabrication site as a fake supplier and cut them POs and do Sales Orders. Does anyone have any other ideas??
Are your methods inclusive of both sites? Or have you split it into a method for Assembly and a separate method for Fabrication? I would recommend making one method in the Assembly site that is using resources in the Fabrication site as part of it. That way, when you release a job for Assembly, it will automatically schedule Fabrication.
As long as you have it set up, you should still get separate P&L. Remember, the transactions come from the Sites where they actually happen and not from the method. If someone logs into a job in Fabrication, as long as you have the Division set on the Site, the transactions should flex.
The more I think about this the more I dont think that will work because the fabrication and assembly have two completely separate schedules and operations teams that manage the schedule so Fab likes to see when Assy orders come in so they can roll into their normal external customer schedule. And Assy wants to stock the parts. I did ask about doing them as non-stock and only order what is exactly needed direct to job and they didn’t like that option.
But they would have two separate schedules as the schedules are based on the site. And any changes to the schedule in one site “should” (I’ve never tested this part) flag the other site of there being an issue with their schedule.
