Welp… There’s not much anyone can do for you then. I’ll paste the SQL preview, but you need to make any BAQ from scratch unless you can find another user on your version. For my baq you must also create two int parameters, YEAR and MONTH. We also only have 3 account segments, so you would need to modify the joins and selects to match your environment.
* Disclaimer!!!
* This is not a real query being executed, but a simplified version for general vision.
* Executing it with any other tool may produce a different result.
select
[MTD_Balances].[Calculated_GL_Level] as [Calculated_GL_Level],
[MTD_Balances].[ExtFinAnlsCd1_InternalCode] as [ExtFinAnlsCd1_InternalCode],
[MTD_Balances].[ExtFinAnlsCd1_Description] as [ExtFinAnlsCd1_Description],
[MTD_Balances].[COASegValues1_StatUOMCode] as [COASegValues1_StatUOMCode],
[MTD_Balances].[GLAcctDisp1_GLAcctDisp] as [GLAcctDisp1_GLAcctDisp],
[MTD_Balances].[GLAcctDisp1_AccountDesc] as [GLAcctDisp1_AccountDesc],
[MTD_Balances].[GLAcctDisp1_SegValue1] as [GLAcctDisp1_SegValue1],
[MTD_Balances].[GLAcctDisp1_SegValue2] as [GLAcctDisp1_SegValue2],
[MTD_Balances].[GLAcctDisp1_SegValue3] as [GLAcctDisp1_SegValue3],
[MTD_Balances].[GLPeriodBal_BalanceAmt01] as [GLPeriodBal_BalanceAmt01],
[MTD_Balances].[Calculated_Prior_Period_Balance] as [Calculated_Prior_Period_Balance],
[MTD_Balances].[GLPeriodBal_BalanceAmt] as [GLPeriodBal_BalanceAmt],
[MTD_Balances].[Calculated_MTD_Balances] as [Calculated_MTD_Balances],
[MTD_Balances].[Calculated_YTD_Balances] as [Calculated_YTD_Balances],
[MTD_Balances].[Calculated_YTD_Average] as [Calculated_YTD_Average],
[MTD_Balances].[Calculated_YTD_Run_Rate] as [Calculated_YTD_Run_Rate],
[MTD_Balances].[COASegValues1_Category] as [COASegValues1_Category],
[MTD_Balances].[COASegValues1_SegmentDesc] as [COASegValues1_SegmentDesc],
[MTD_Balances].[GLPeriodBal_FiscalYear01] as [GLPeriodBal_FiscalYear01],
[MTD_Balances].[GLPeriodBal_FiscalPeriod01] as [GLPeriodBal_FiscalPeriod01],
[MTD_Balances].[GLBudgetDtl_BudgetAmt] as [GLBudgetDtl_BudgetAmt],
(case
when MTD_Balances.GLBudgetDtl_BudgetAmt > 0 or MTD_Balances.GLBudgetDtl_BudgetAmt < 0 then MTD_Balances.GLBudgetDtl_BudgetAmt - MTD_Balances.Calculated_MTD_Balances
else 0
end) as [Calculated_BudgetVsActual],
[MTD_Balances].[GLBudgetHd_TotalBudgetAmt] as [GLBudgetHd_TotalBudgetAmt],
(case
when MTD_Balances.GLBudgetHd_TotalBudgetAmt > 0 or MTD_Balances.GLBudgetHd_TotalBudgetAmt < 0 then MTD_Balances.GLBudgetHd_TotalBudgetAmt - MTD_Balances.Calculated_YTD_Balances
else 0
end) as [Calculated_YTDBudgetVsActual]
from (select
(Left(GLAcctDisp1.SegValue1,1)) as [Calculated_GL_Level],
[ExtFinAnlsCd1].[InternalCode] as [ExtFinAnlsCd1_InternalCode],
[ExtFinAnlsCd1].[Description] as [ExtFinAnlsCd1_Description],
[COASegValues1].[StatUOMCode] as [COASegValues1_StatUOMCode],
[GLAcctDisp1].[GLAcctDisp] as [GLAcctDisp1_GLAcctDisp],
[GLAcctDisp1].[AccountDesc] as [GLAcctDisp1_AccountDesc],
[GLAcctDisp1].[SegValue1] as [GLAcctDisp1_SegValue1],
[GLAcctDisp1].[SegValue2] as [GLAcctDisp1_SegValue2],
[GLAcctDisp1].[SegValue3] as [GLAcctDisp1_SegValue3],
[GL_Bal_By_Period2].[GLPeriodBal_BalanceAmt] as [GLPeriodBal_BalanceAmt01],
(sum(GL_Bal_By_Period1.GLPeriodBal_BalanceAmt)) as [Calculated_Prior_Period_Balance],
[GL_Bal_By_Period].[GLPeriodBal_BalanceAmt] as [GLPeriodBal_BalanceAmt],
((case when GL_Level > 2 then GL_Bal_By_Period.GLPeriodBal_BalanceAmt else (case when GL_Bal_By_Period.GLPeriodBal_BalanceAmt is null then Prior_Period_Balance else GL_Bal_By_Period.GLPeriodBal_BalanceAmt + ISNULL(Prior_Period_Balance, 0) end) end)) as [Calculated_MTD_Balances],
((case when Prior_Period_Balance is null then GL_Bal_By_Period.GLPeriodBal_BalanceAmt else (case when GL_Bal_By_Period.GLPeriodBal_BalanceAmt is null then Prior_Period_Balance else GL_Bal_By_Period.GLPeriodBal_BalanceAmt + Prior_Period_Balance end) end)) as [Calculated_YTD_Balances],
((case when GL_Level > 2 and YTD_Balances <> 0 then YTD_Balances / @MONTH else 0 end)) as [Calculated_YTD_Average],
(YTD_Average * 12) as [Calculated_YTD_Run_Rate],
[COASegValues1].[Category] as [COASegValues1_Category],
[COASegValues1].[SegmentDesc] as [COASegValues1_SegmentDesc],
[GL_Bal_By_Period].[GLPeriodBal_FiscalYear] as [GLPeriodBal_FiscalYear01],
[GL_Bal_By_Period].[GLPeriodBal_FiscalPeriod] as [GLPeriodBal_FiscalPeriod01],
[GLBudgetDtl].[BudgetAmt] as [GLBudgetDtl_BudgetAmt],
[GLBudgetHd].[TotalBudgetAmt] as [GLBudgetHd_TotalBudgetAmt]
from Erp.GLAcctDisp as [GLAcctDisp1]
inner join Erp.GLAccount as [GLAccount1] on
GLAcctDisp1.Company = GLAccount1.Company
and GLAcctDisp1.COACode = GLAccount1.COACode
and GLAcctDisp1.GLAccount = GLAccount1.GLAccount
left outer join (select
[GLPeriodBal].[FiscalYear] as [GLPeriodBal_FiscalYear],
[GLPeriodBal].[FiscalPeriod] as [GLPeriodBal_FiscalPeriod],
[GLAcctDisp].[GLAcctDisp] as [GLAcctDisp_GLAcctDisp],
[GLAcctDisp].[SegValue1] as [GLAcctDisp_SegValue1],
[GLAcctDisp].[SegValue2] as [GLAcctDisp_SegValue2],
[GLAcctDisp].[SegValue3] as [GLAcctDisp_SegValue3],
[GLPeriodBal].[DebitAmt] as [GLPeriodBal_DebitAmt],
[GLPeriodBal].[CreditAmt] as [GLPeriodBal_CreditAmt],
[GLPeriodBal].[CarryForwardBalance] as [GLPeriodBal_CarryForwardBalance],
[GLPeriodBal].[OpenBalance] as [GLPeriodBal_OpenBalance],
[GLPeriodBal].[BalanceAmt] as [GLPeriodBal_BalanceAmt],
[GLAccount].[AccountDesc] as [GLAccount_AccountDesc],
[COASegValues].[StatUOMCode] as [COASegValues_StatUOMCode],
[COASegValues].[SegmentCode] as [COASegValues_SegmentCode],
[COASegValues].[Category] as [COASegValues_Category],
[COASegValues].[SegmentDesc] as [COASegValues_SegmentDesc],
[COASegValues].[ExtAnalysisCode] as [COASegValues_ExtAnalysisCode],
[ExtFinAnlsCd].[Description] as [ExtFinAnlsCd_Description],
[COASegValues].[SegmentName] as [COASegValues_SegmentName]
from Erp.GLPeriodBal as [GLPeriodBal]
right outer join Erp.GLAcctDisp as [GLAcctDisp] on
GLPeriodBal.SegValue1 = GLAcctDisp.SegValue1
and GLPeriodBal.SegValue2 = GLAcctDisp.SegValue2
and GLPeriodBal.SegValue3 = GLAcctDisp.SegValue3
left outer join Erp.GLAccount as [GLAccount] on
GLAccount.Company = GLAcctDisp.Company
and GLAccount.COACode = GLAcctDisp.COACode
and GLAccount.GLAccount = GLAcctDisp.GLAccount
left outer join Erp.COASegValues as [COASegValues] on
GLAccount.Company = COASegValues.Company
and GLAccount.SegValue1 = COASegValues.SegmentCode
left outer join Erp.ExtFinAnlsCd as [ExtFinAnlsCd] on
COASegValues.Company = ExtFinAnlsCd.Company
and COASegValues.ExtAnalysisCode = ExtFinAnlsCd.InternalCode
where (GLPeriodBal.FiscalYear = CAST(@YEAR AS INT)
and GLPeriodBal.FiscalPeriod >= 0
and GLPeriodBal.FiscalPeriod <= CAST(@MONTH AS INT))) as [GL_Bal_By_Period] on
GLAccount1.SegValue1 = GL_Bal_By_Period.GLAcctDisp_SegValue1
and GLAccount1.SegValue2 = GL_Bal_By_Period.GLAcctDisp_SegValue2
and GLAccount1.SegValue3 = GL_Bal_By_Period.GLAcctDisp_SegValue3
and ( GL_Bal_By_Period.GLPeriodBal_FiscalYear = @YEAR
and GL_Bal_By_Period.GLPeriodBal_FiscalPeriod = @MONTH )
and GLPeriodBal.FiscalPeriod <= CAST(@MONTH AS INT))) as [GL_Bal_By_Period1] on
GLAccount1.SegValue1 = GL_Bal_By_Period1.GLAcctDisp_SegValue1
and GLAccount1.SegValue2 = GL_Bal_By_Period1.GLAcctDisp_SegValue2
and GLAccount1.SegValue3 = GL_Bal_By_Period1.GLAcctDisp_SegValue3
and ( GL_Bal_By_Period1.GLPeriodBal_FiscalYear = @YEAR
and GL_Bal_By_Period1.GLPeriodBal_FiscalPeriod < @MONTH )
left outer join Erp.COASegValues as [COASegValues1] on
GLAccount1.Company = COASegValues1.Company
and GLAccount1.SegValue1 = COASegValues1.SegmentCode
left outer join Erp.ExtFinAnlsCd as [ExtFinAnlsCd1] on
COASegValues1.Company = ExtFinAnlsCd1.Company
and COASegValues1.ExtAnalysisCode = ExtFinAnlsCd1.InternalCode
and GLPeriodBal.FiscalPeriod <= CAST(@MONTH AS INT))) as [GL_Bal_By_Period2] on
GLAccount1.SegValue1 = GL_Bal_By_Period2.GLAcctDisp_SegValue1
and GLAccount1.SegValue2 = GL_Bal_By_Period2.GLAcctDisp_SegValue2
and GLAccount1.SegValue3 = GL_Bal_By_Period2.GLAcctDisp_SegValue3
and ( GL_Bal_By_Period2.GLPeriodBal_FiscalYear = @YEAR
and GL_Bal_By_Period2.GLPeriodBal_FiscalPeriod = 0 )
left outer join Erp.GLBudgetDtl as [GLBudgetDtl] on
GLBudgetDtl.Company = GLAccount1.Company
and GLBudgetDtl.SegValue1 = GLAccount1.SegValue1
and GLBudgetDtl.SegValue2 = GLAccount1.SegValue2
and GLBudgetDtl.SegValue3 = GLAccount1.SegValue3
and ( GLBudgetDtl.BalanceType = 'D'
and GLBudgetDtl.FiscalYear = @YEAR
and GLBudgetDtl.FiscalPeriod = @MONTH )
left outer join Erp.GLBudgetHd as [GLBudgetHd] on
GLBudgetDtl.Company = GLBudgetHd.Company
and GLBudgetDtl.BookID = GLBudgetHd.BookID
and GLBudgetDtl.BalanceAcct = GLBudgetHd.BalanceAcct
and GLBudgetDtl.BalanceType = GLBudgetHd.BalanceType
and GLBudgetDtl.FiscalYear = GLBudgetHd.FiscalYear
and GLBudgetDtl.FiscalYearSuffix = GLBudgetHd.FiscalYearSuffix
and GLBudgetDtl.FiscalCalendarID = GLBudgetHd.FiscalCalendarID
and GLBudgetDtl.BudgetCodeID = GLBudgetHd.BudgetCodeID
group by
[ExtFinAnlsCd1].[InternalCode],
[ExtFinAnlsCd1].[Description],
[COASegValues1].[StatUOMCode],
[GLAcctDisp1].[GLAcctDisp],
[GLAcctDisp1].[AccountDesc],
[GLAcctDisp1].[SegValue1],
[GLAcctDisp1].[SegValue2],
[GLAcctDisp1].[SegValue3],
[GL_Bal_By_Period2].[GLPeriodBal_BalanceAmt],
[GL_Bal_By_Period].[GLPeriodBal_BalanceAmt],
[COASegValues1].[Category],
[COASegValues1].[SegmentDesc],
[GL_Bal_By_Period].[GLPeriodBal_FiscalYear],
[GL_Bal_By_Period].[GLPeriodBal_FiscalPeriod],
[GLBudgetDtl].[BudgetAmt],
[GLBudgetHd].[TotalBudgetAmt]) as [MTD_Balances]
Godspeed
