Trouble using Access to connect to ODBC
I’ve tried adding a new string to the ODBC.Ini but I added (WorkArounds2=8192) that didn’t work. Should I change the value to 40960?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steven Gotschall
Sent: Tuesday, November 09, 2010 1:45 PM
Subject: Re: [Vantage] trouble using Access to connect to ODBC
I don't have the instructions handy, but if you search the Microsoft site for
WorkAround 40960 it will tell you how to fix this problem.
From: Stephen Freeman <stephenf@...<mailto:stephenf%40alspi.com>>
To: "Vantage E Group (vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>)" <vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
Sent: Tue, November 9, 2010 2:36:39 PM
Subject: [Vantage] trouble using Access to connect to ODBC
I'm doing some testing with Epicor 9.04 . Using the OpenEdge 10.1 C Driver I can
connect using Crystal Reports. When I try connecting using Access 2007 I get up
to the point of Link Tables, I select a table, hit OK, then I get "Reserved
error (-7748) there is no message for this error.".
Any ideas on this?
I'm doing some testing with Epicor 9.04 . Using the OpenEdge 10.1 C Driver I can connect using Crystal Reports. When I try connecting using Access 2007 I get up to the point of Link Tables, I select a table, hit OK, then I get "Reserved error (-7748) there is no message for this error.".
Any ideas on this?
Â
Â
To: "Vantage E Group (vantage@yahoogroups.com)" <vantage@yahoogroups.com>
Â
Any ideas on this?
