Hopefully this has not been discussed in another thread, as I wouldn’t even know how to search for it.
I have a project where I am working on writing custom function to move sales order releases around to different plants based on what they have available to ship. If there are partial quantities available, it will split the release and move the new release to the available plant. If the current plant has a partial quantity, it reduces the current release to the available, and then a new release is created for the remaining quantity. That new release then loops through the code again to go through the process. The function needs to loop as long as the remaining quantity >0.
I am testing the function with an order that is for 55. Current plant has 51, and 2 other plants have 1 each.
I expect the function to reduce release 1 to 51, then create release 2 for 4, then run the code again to create release 3 and move 1 to plant 2 and then create release 4 to move 1 to plant 3, leaving remaining 1 on release 2 in the current plant.
Running the function now correctly reduces release 1 to 51, and creates release 2 at quantity 4.
At this point it looks like the function gets “stuck” in the loop. there are no errors, and I have to recycle the app pool to make sure it is not still running. No other releases are created on the order.
outstrMsg = "";
var context = (Erp.ErpContext)Ice.Services.ContextFactory.CreateContext();
var erpContext = new Erp.Internal.Lib.CCredChk(context);
decimal curavail=0;
decimal regavail=0;
decimal avail=0;
string regplant="";
string regwhse="";
string alplant="";
string alwhse="";
int release=0;
decimal remaining=0;
int order=0;
int line=0;
bool newrel=false;
//using(var txScope = Ice.IceContext.CreateDefaultTransactionScope())
foreach (var vDbOrderrelExist in erpContext.Db.OrderRel.Where(x => x.Company == "MJP" && x.OpenRelease==true && x.OrderNum==901943))
//foreach (var vDbOrderrelExist in erpContext.Db.OrderRel.Where(x => x.Company == "MJP" && x.OpenRelease==true && x.BuyToOrder==false && (x.Plant=="MJP02" || x.Plant=="MJP20" || x.Plant=="MJP30" || x.Plant=="MJP55")))
if(vDbOrderrelExist!=null)
order=vDbOrderrelExist.OrderNum;
line=vDbOrderrelExist.OrderLine;
release=vDbOrderrelExist.OrderRelNum;
//outstrMsg += "Order Number: " + vDbOrderrelExist.OrderNum.ToString() + " " + DateTime.Now + Environment.NewLine;
remaining= (vDbOrderrelExist.OurReqQty - vDbOrderrelExist.OurStockShippedQty);
while(remaining>0)
using (var svc = Ice.Assemblies.ServiceRenderer.GetService<Ice.Contracts.DynamicQuerySvcContract>(context))
Ice.Tablesets.DynamicQueryTableset dsQuery = svc.GetByID("CheckAftermarketInventory");
if (dsQuery != null)
Ice.Tablesets.QueryExecutionTableset dsBAQ = svc.GetQueryExecutionParameters(dsQuery);
dsBAQ.ExecutionParameter[0].ParameterID = "pOrderNum";
dsBAQ.ExecutionParameter[0].IsEmpty = false;
dsBAQ.ExecutionParameter[0].ParameterValue = order.ToString();
dsBAQ.ExecutionParameter[1].ParameterID = "pOrderLine";
dsBAQ.ExecutionParameter[1].IsEmpty = false;
dsBAQ.ExecutionParameter[1].ParameterValue = line.ToString();
dsBAQ.ExecutionParameter[2].ParameterID = "pOrderRel";
dsBAQ.ExecutionParameter[2].IsEmpty = false;
dsBAQ.ExecutionParameter[2].ParameterValue = release.ToString();
DataSet results = svc.Execute(dsQuery,dsBAQ);
if(results ==null)
remaining=0;
if(results !=null)
//outstrMsg += "Allocation found " + vDbOrderrelExist.OrderNum.ToString() + "-" + vDbOrderrelExist.OrderLine.ToString() + "-" + vDbOrderrelExist.OrderRelNum.ToString() + " " + DateTime.Now + Environment.NewLine;
foreach (DataTable table in results.Tables)
if(table ==null)
remaining=0;
if(table!=null)
if(table.TableName.Contains("Results"))
if(table.Rows.Count==0)
remaining=0;
if(table.Rows.Count>0)
foreach (DataRow row in table.Rows)
if(row !=null)
if(row["Calculated_CurAvail"]!=System.DBNull.Value)
curavail=Convert.ToDecimal(row["Calculated_CurAvail"]);
if(row["Calculated_RegAvail"]!=System.DBNull.Value)
regavail=Convert.ToDecimal(row["Calculated_RegAvail"]);
if(row["Calculated_Avail"]!=System.DBNull.Value)
avail=Convert.ToDecimal(row["Calculated_Avail"]);
if(row["OrderHed_ShortChar02"]!=System.DBNull.Value)
regplant=row["OrderHed_ShortChar02"].ToString();
regwhse=row["PartWhse2_WarehouseCode"].ToString();
if(row["PartPlant_Plant"]!=System.DBNull.Value)
alplant=row["PartPlant_Plant"].ToString();
if(row["PartPlant_PrimWhse"]!=System.DBNull.Value)
alwhse=row["PartPlant_PrimWhse"].ToString();
if(curavail>=remaining)
remaining=0;
if(curavail<=0 && regavail>=remaining && (regplant=="MJP02" || regplant=="MJP20" || regplant=="MJP30" || regplant=="MJP55"))
this.CallService<Erp.Contracts.SalesOrderSvcContract>(osc => {
Erp.Tablesets.SalesOrderTableset sods = osc.GetByID(order);
var desiredRelease = sods.OrderRel.Where(r => r.OrderLine == line && r.OrderRelNum == release);
foreach(var rel in desiredRelease)
rel.Plant=regplant;
rel.WarehouseCode=regwhse;
rel.PurPoint="";
rel.RowMod="U";
remaining=0;
osc.ChangePlant(regplant,ref sods);
osc.Update(ref sods);
outstrMsg += order.ToString() + "-" + line.ToString() + "-" + release.ToString() + " Allocated to " + regplant + DateTime.Now + Environment.NewLine;
if(curavail<=0 && regavail<=0 && avail>=remaining)
rel.Plant=alplant;
rel.WarehouseCode=alwhse;
rel.PurPoint="";
rel.RowMod="U";
remaining=0;
osc.ChangePlant(alplant,ref sods);
outstrMsg += order.ToString() + "-" + line.ToString() + "-" + release.ToString() + " Allocated to " + alplant + DateTime.Now + Environment.NewLine;
if(curavail>0 && curavail<remaining)
decimal tomove=0;
string opWarningMsg="";
remaining=remaining-curavail;
rel.SellingReqQty=curavail;
rel.OurReqQty=curavail;
rel.PurPoint="";
rel.RowMod="U";
osc.ChangeSellingReqQty(ref sods,curavail,out opWarningMsg);
if(remaining>0)
osc.GetNewOrderRel(ref sods,order,line);
var desiredRelease = sods.OrderRel.Where(r => r.OrderLine == line && r.OrderRelNum == 0);
rel.SellingReqQty=remaining;
rel.OurReqQty=remaining;
rel.PurPoint="";
rel.RowMod="A";
osc.ChangeSellingReqQty(ref sods,remaining,out opWarningMsg);
outstrMsg += order.ToString() + "-" + line.ToString() + "-" + release.ToString() + " Quantity reduced to " + curavail.ToString("#.##")+ " " + DateTime.Now + Environment.NewLine;
release+=1;
newrel=true;
outstrMsg += order.ToString() + "-" + line.ToString() + "-" + release.ToString() + " Created at quantity " + remaining.ToString("#.##")+ " " + DateTime.Now + Environment.NewLine;
}//remaining >0
}//partial current, create new release
if(curavail<=0 && regavail<remaining && regavail>0 && newrel==false && (regplant=="MJP02" || regplant=="MJP20" || regplant=="MJP30" || regplant=="MJP55"))
decimal tomove=0;
tomove=regavail;
remaining=remaining-regavail;
rel.PurPoint="";
rel.RowMod="U";
outstrMsg += order.ToString() + "-" + line.ToString() + "-" + release.ToString() + " Quantity reduced to " + remaining.ToString("#.##")+ " " + DateTime.Now + Environment.NewLine;
if(tomove>0)
rel.SellingReqQty=tomove;
rel.OurReqQty=tomove;
rel.PurPoint="";
rel.RowMod="A";
osc.ChangeSellingReqQty(ref sods,tomove,out opWarningMsg);
desiredRelease = sods.OrderRel.Where(r => r.OrderLine == line && r.OrderRelNum == release+1);
rel.Plant=regplant;
rel.PurPoint="";
rel.RowMod="U";
newrel=false;
outstrMsg += order.ToString() + "-" + line.ToString() + "-" + release+1.ToString() + " Created at quantity " + tomove.ToString("#.##") + " and Allocated to Plant " + regplant + " " + DateTime.Now + Environment.NewLine;
tomove=0;
curavail=0;
regavail=0;
}//remaining >0
}//partial region, create new release and move
if(curavail<=0 && regavail<=0 && avail<remaining && avail>0 && newrel==false)
decimal tomove=0;
tomove=avail;
remaining=remaining-avail;
rel.PurPoint="";
rel.RowMod="U";
if(tomove>0)
rel.PurPoint="";
rel.RowMod="A";
rel.Plant=alplant;
rel.PurPoint="";
rel.RowMod="U";
newrel=false;
outstrMsg += order.ToString() + "-" + line.ToString() + "-" + release+1.ToString() + " Created at quantity " + tomove.ToString("#.##") + " and Allocated to Plant " + alplant + " " + DateTime.Now + Environment.NewLine;
tomove=0;
avail=0;
}//remaining >0
if(curavail<=0 && regavail<=0 && avail<=0 && remaining>0)
if(vDbOrderrelExist.Plant!="MJP02")
rel.Plant="MJP02";
rel.WarehouseCode="02";
rel.PurPoint="";
rel.RowMod="U";
osc.ChangePlant("MJP02",ref sods);
}//remaining quantity <> MJP02
remaining=0;
}//nothing on hand remaining>0
}//Row!=null
}//each datarow in table.rows
}// loop through allocation
}//table contains results
}//table!=null
}//each table in results
}//Loop through order lines
}//check if data in allocation table
}//build allocation table
}// loop for creating new releases
} //if orderrel exists
}//loop order releases that are open in specific plants
// txScope.Complete();
if(outstrMsg=="")
outstrMsg+="No Order Releases to Allocate " + Environment.NewLine;
System.IO.File.AppendAllText(@"\\servername\Supporting Files\Logs\AftermarketAllocation.txt", outstrMsg.Trim() + " " + DateTime.Now + " " + Session.AppServerURL + Environment.NewLine);
