It’s probably not required, just depends on what your goal is. That wasn’t apparent in your original posting. Since it sounds like you’re really bringing back static data for reference from unrelated sources, what about just embedding a dashboard with it set to auto populate?
Rob Bucek
Production Control Manager
D&S Manufacturing
301 E. Main St. | PO Box 279
Black River Falls, WI 54615
715-284-5376 Ext. 311
Mobile: 715-896-3119
rbucek@...
www.dsmfg.com<http://www.dsmfg.com>
Sent: Thursday, October 1, 2015 3:34 PM
Subject: [Vantage] Re: Troubles Using BAQDataView
Thanks for the example. What I see that's different than what I am doing is that you're subscribing to publisher. Is that required for this to work?
My BAQ returns a list of standard notes that we defined as a User Code Type. I want to allow the user to select some of the notes and add them to Quote Header Comments. So, there's really no publish/subscribe scenario here, unless I do it on Company. In which case, I probably need Company in my BAQ.
Bob Beaghan
Rob Bucek
D&S Manufacturing
rbucek@...
Bob Beaghan
