I’m trying to create a BPM to set LockQty to true when the Quick Job Entry is marked as Engineered. I’ve tried several things already, but you can see the most recent below. I added this as a BPM for QuickJobEntry.GeneratedJob.Post. The first info message fires, but not the second. The job gets created, but the LockQty never gets set.
find first ttQuickJob where ttQuickJob.RowMod = 'U' or ttQuickJob.RowMod = 'A' . /* If this Quick Job is Engineered, set JobHead.LockQty to true */ if ttQuickJob.EnableEngineered then do : find first JobHead where JobHead.JobNum = ttQuickJob.JobNum and JobHead.Company = cur-comp no-lock no-error . {lib\PublishInfoMsg.i &InfoMsg = "'Update JobHead ' + JobHead.JobNum + '.'" } . assign JobHead.LockQty = true. {lib\PublishInfoMsg.i &InfoMsg = "'JobHead LockQty(' + STRING(JobHead.LockQty) + ').'" } . end .
