I was wondering if there is a data dictionary for TT tables? There are some things in TT tables that aren’t in regular tables (I think?)
Other than what is available in the Field Help I don’t think there is no.
Go to the Extended Property Maintenance UI - that will show you the Fields in the TT tables and it will tell you if the TT table is based on a database table. The TT tables are the tables defined for the Client Dataset and the fields include Actual DB Columns, Linked DB Columns (Description for a Code that is an actual column), and Logical Columns defined by the Epicor coders.
