# TT5B Manual needed
**Category:** [Yahoo Archive](https://www.epiusers.help/c/yahoo-archive/9)
**Created:** 2000-08-01 12:10 UTC
**Views:** 476
**Replies:** 4
**URL:** https://www.epiusers.help/t/tt5b-manual-needed/631
## Post #1 by @system
Nancy,
If this number is correct:
<excerpt from TT5 Manual>
Power output from power adapter (rated)
voltage: 12Vrms AC
Current(Max): 500 milliamps
Rated Power: 6VA
Does this help?
Darren Mann
Miller Products Co.
> -----Original Message-----
> From: Dunn, Nancy [mailto:ndunn@...]
> Sent: Tuesday, August 01, 2000 10:31 AM
> To: 'vantage@egroups.com'
> Subject: RE: [Vantage] TT5B Manual needed
> Darren,
> Do you know the voltage for the port?
> From: Darren Mann [mailto:dmann@...]
> The round power port is for power from a transformer power
> supply. Since
> the TT5 gets its power from the network controller across the cable it
> really isn't neccessary unless you wish to configure the TT5 while the
> controller is down or the unit is not plugged into the network.
## Post #2 by @system
Does anyone have a schematic or book that shows what the connection on the
back of a TT5B are.
I am especially interested in the round "power" port between the RJ45 and
serial port.
You can fax me at 937 667-5178 or Email at
ndunn@...
Thank you for you help
Nancy Dunn
Winco Industries Inc.
Voice: 937 667-4476
## Post #3 by @system
The power port is used if the TT5 is located more than 100 feet from the hub
(TLD2 or TIM1B) from which it normally draws power.
ndunn@...]
Sent: Tuesday, August 01, 2000 9:51 AM
To: Vantage Onelist (E-mail)
Subject: [Vantage] TT5B Manual needed
back of a TT5B are.
serial port.
ndunn@...
Nancy Dunn
Voice: 937 667-4476
please go to the following link:
http://www.egroups.com/files/vantage/
## Post #4 by @system
Nancy,
The round power port is for power from a transformer power supply. Since
Darren Mann
Miller Products Co.
> Sent: Tuesday, August 01, 2000 8:51 AM
> connection on the
> back of a TT5B are.
> the RJ45 and
> serial port.
> You can fax me at 937 667-5178 or Email at ndunn@...
> Nancy Dunn
> Voice: 937 667-4476
> ------<e|-
> Download iPlanet Web Server, FastTrack Edition 4.1 for FREE,
> and start publishing dynamic web pages today!
> http://click.egroups.com/1/7628/13/_/411782/_/965137886/
> ------|e>-
> Report Files, please go to the following link:
> try it, go to www.egroups.com, login and be sure to save your
> password, choose My Groups, choose Vantage, then choose
> Files. If you save the password, the link above will work
## Post #5 by @system
Darren,
dmann@...]
**Canonical:** https://www.epiusers.help/t/tt5b-manual-needed/631
**Original content:** https://www.epiusers.help/t/tt5b-manual-needed/631
