Turn on barcoding
You need to install the barcode font on your PC.
Somewhere within the Epicor installation there should be a file called DataWorks
Bar 39 9it's a font).
You need to drop this in your C:/windows/font folder.
From: "michael.hutcheson@..." <michael.hutcheson@...>
Sent: Fri, 25 March, 2011 15:52:17
Subject: [Vantage] Re: turn on barcoding
Â
I've done this but just get a bunch of large numbers seperated by '*'
How do I actually get the black stripes?
--- In vantage@yahoogroups.com, "markbetts66" <markbetts66@...> wrote:
> When you print of the job traveller there is a check box for "Bar codes"
> --- In vantage@yahoogroups.com, "michael.hutcheson@" <michael.hutcheson@>
>wrote:
> > Hello,
> > How do I actually turn bar coding on in vantage 8.03.406? I need it to appear
>on every operation on the Job Traveller.
> > Regards,
> > Michael
Hello,
How do I actually turn bar coding on in vantage 8.03.406? I need it to appear on every operation on the Job Traveller.
Regards,
Michael
--- In vantage@yahoogroups.com, "michael.hutcheson@..." <michael.hutcheson@...> wrote:
> Hello,
> Regards,
> Michael
> --- In vantage@yahoogroups.com, "michael.hutcheson@" <michael.hutcheson@> wrote:
> > Hello,
> > Regards,
> > Michael
Hi Michael,
On Fri, Mar 25, 2011 at 11:52 AM, michael.hutcheson@...
You can get the White Stripes here in Detroit but to get the black
strips, you need to have the bar code font. On our systems it's a file
called:
dwbar39.ttf
If it's not in your system, just copy it from another system into the
Windows\Font folder.
Mark W.
Ah You are missing a font. See your IT guy about getting the fond installed.
Hi we just did this in Crystal Reports but the problem we had the same problem. This is normally caused by not having the font installed on the client.
> > > Hello,
> > > Regards,
> > > Michael
