I am trying to develop a UBAQ to update the KanBan information in PartWhse. The selection criteria resides in the Part table (Part.InActive, Part.RunOut), so I have to join PartWhse and Part.
When I saved the query the first time I got three error messages:
Expression for PartWhse.Plant contains non-existent result column
Expression for PartWhse.PartNum contains non-existent result column
Expression for PartWhse.WarehouseCode contains non-existent result column
So I went back and added PartWhse.PartNum and PartWhse.WarehouseCode to the query. Now I am down to this single error message:
Hereās the problem: there is no PartWhse.Plant field so I canāt add it. I didnāt find it in my BAQ field list, so checked the Data Dictionary just in case. Nothing doing.
Anyone seen this before or have any idea how to get around it? DMT will not let me make these changes because I actually want to remove the KBCode and associated values.
UBAQ Trying to update a field in PartWhse but it is asking for field expression for PartWhse.Plant but this doenāt exist.
Error
One or more BPM directives are marked as outdated due to compilation errors. Please inspect and correct. Method: Ice.CPI001/EOInvUpdTEST.Update, Directive: ##BASE##, Compile error(s): Error CS1061: āEpicor.Customization.Bpm.Ubaq401F7C33CB8842F6866C1A07EA9EB9D4.ResultsUbaqTableā does not contain a definition for āPartPlant_Plantā and no extension method āPartPlant_Plantā accepting a first argument of type āEpicor.Customization.Bpm.Ubaq401F7C33CB8842F6866C1A07EA9EB9D4.ResultsUbaqTableā could be found (are you missing a using directive or an assembly reference?) [Update.Base.##BASE##.cs(131,67)] Error CS1061: āEpicor.Customization.Bpm.Ubaq401F7C33CB8842F6866C1A07EA9EB9D4.ResultsUbaqTableā does not contain a definition for āPartPlant_Plantā and no extension method āPartPlant_Plantā accepting a first argument of type āEpicor.Customization.Bpm.Ubaq401F7C33CB8842F6866C1A07EA9EB9D4.ResultsUbaqTableā could be found (are you missing a using directive or an assembly reference?) [Update.Base.##BASE##.cs(156,196)]
Resolution
In the Update > Update Processing tab for ttPartWhse enter in an expression Constants.CurrentPlant
Hello,
I know you were able to get around it using a UBAQ, but have you been able to figure out the DMT situation? It seems like I wonāt be able to DMT into the PartWhse table?
Thank you!
Edit:
I was able to fill the DMT-required PartWhse.Plant field using the PartPlant.Plant field that matched with the PartWhse when linking
