Yes I actually have the fix
re-name your ChildTable View from UD04View to AutoAttachUD04View within the
code in InitializeUD function
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Wed, Feb 16, 2011 at 11:34 AM, gmcdonald333 <gmcdonald333@...>wrote:
> Checked on 9.05.600B and the same results. Is there any kind of fix for
> this?
> Gene McDonald
> --- In vantage@yahoogroups.com, "Chris Henzel" <chrish@...> wrote:
> > Checked on 9.05.602A - Same error.
> > Regards
> > Chris
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > Of Jose Gomez
> > Sent: 03 February 2011 16:39
> > To: Vantage
> > Subject: [Vantage] UD Child Table (Can you replicate my error please)
> > Hi All
> > I have two instances of epicor 9.04 and 9.05 I am trying to simply made
> > UD04
> > table a child of OrderDtl on a simple customization. I have done this a
> > million times in other places but for some reason on Order Entry
> > when I make UD04 a child of OrderDtl I get an error on the form that
> > says
> > Can't find Column OrderNum.
> > This is with JUST epicor code none of my own. Can someone please take 5
> > minutes and see if you replicate my problem. Here are the steps
> > Go to Order Entry (in Customization Mode)
> > To to Toosl, Wizards, Customization Wizard
> > Select Add User Table as Child
> > Click Launch Wizard
> > On DataViews selct orderDtl
> > On UD Adapter Select UD04
> > Click Next
> > On Fields Select OrderNum -> Key1
> > OrderLine -> Key2
> > Add Both of Those and Select Finish
> > Save your customization and then try to open a Sales Order
> > I get error
> > The following application error was encountered:
> > Cannot find column [OrderNum].
> > I REALLY would appreciate anyone could replicate this (it takes like 3
> > minutes) and tell me if you get the same problem. I did it on 9.04 and
> > 9.05
> > with the same results
> > Thank you!!
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@... <mailto:jose%40josecgomez.com>
> > Chris Henzel Epicor 9 Project Manager Tel: +44 (0)1582 436150 Mob: 07836
> 314164
> > This message contains confidential information and is intended only for
> the intended recipients. If you are not an intended recipient you should not
> disseminate, distribute or copy this email. Please notify the sender if you
> have received this email by mistake and delete it from your system.Email
> transmission cannot be guaranteed to be secure or error-free as information
> could be intercepted, corrupted, lost, destroyed, arrive late or incomplete,
> or contain viruses. The sender does not accept liability for any errors or
> omissions in the contents of this message, which arise as a result of email
> transmission. Registered Office: Hayward Tyler Ltd, 1 Kimpton Road, Luton,
> LU1 3LD, England. Tel: +44 (0)1582 731144. Company No. 3450138.
