UD Entry Screen
I believe that's only if you're on SQL.
On Thu, Dec 15, 2011 at 4:39 PM, tmadhan04 <tmadhan04@...> wrote:
> Sorry forgot to mention, once you change the extended properties you have
> to restart the appservers in order to show the new label
> --- In vantage@yahoogroups.com, "tmadhan04" <tmadhan04@...> wrote:
> > you can change the Label name thru Extended properties under utilities
> menu and that should show up the new label name in the search window.
> > --- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@> wrote:
> > > I have a custom screen that uses table UD02 for some production
> controls.
> > > I���ve added the UD02 Entry screen to the menu and everything works.
> > > When you click on the [Search...] button you can search but the
> columns shown in the search window are ���Key1�� , ���Key2�� , etc. Is
> there a way to rename these columns in the search grid?
*John Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
I have a custom screen that uses table UD02 for some production controls.
I’ve added the UD02 Entry screen to the menu and everything works.
When you click on the [Search...] button you can search but the columns shown in the search window are “Key1”, “Key2”, etc. Is there a way to rename these columns in the search grid?
I would do a BAQ search and rename the headings there.
Mark W.
On Wed, Dec 14, 2011 at 2:11 PM, Vic Drecchio
> I�ve added the UD02 Entry screen to the menu and everything works.
> shown in the search window are �Key1�, �Key2�, etc. Is there a way to
you can change the Label name thru Extended properties under utilities menu and that should show up the new label name in the search window.
Sorry forgot to mention, once you change the extended properties you have to restart the appservers in order to show the new label
