Hi again,
I've only created a EpiRetiverCombo, with Fon.Fob, and then choosed the Epibinding QuoteHed.Character01, and in the Extended Properties i've added Like: Fob, Like Field: FOB (and when adding that part the Right Click/Fob Entry displayed, but not the refresh list as i thought).
To populate it with the Fob from the Customer i've used a BPM on the Quote.GetCustomerInfo method.
What could be missing?
Kind regards,
Lisa
Kind regards,
Lisa
--- In vantage@yahoogroups.com, Joshua Giese <jgiese@...> wrote:
> Just a standard EpiCombo using the EpiBOName, DisplayMember, EpiTableName, ValueMember, etc. properties
> Would have to see how you coded it up to know what's different. The EpiCombo group properties for the control are basically equal to the BOReader.
> Joshua Giese
> CTO
> 920.437.6400 Ext. 337
> Site ID: 27450-E905700B2-SQL64
> From: "lisassar" <lisa.saren@...>
> To: vantage@yahoogroups.com
> Sent: Thursday, April 25, 2013 8:10:03 AM
> Subject: [Vantage] Re: UD Field, Right Click/Refresh List - how can I get it?
> Okey, and by that you mean? Whats the difference from how I've created it?
> Kind regards,
> Lisa
> --- In vantage@yahoogroups.com , Joshua Giese <jgiese@> wrote:
> > I've always used the same principle on EpiCombos as you would for UDCodes in those types of situations. In those cases I don't think I've ever noticed "Refresh List..." not being available.
> > Joshua Giese
> > CTO
> > From: "lisassar" <lisa.saren@>
> > Sent: Wednesday, April 24, 2013 9:34:25 AM
> > Subject: [Vantage] UD Field, Right Click/Refresh List - how can I get it?
> > Hi everybody!
> > I've created a UD field (EpiRetriver Combo of FOB.Fob, QuoteHed.Character01) in the Quote Entry which takes the value from the Customer.DefaultFOB via a BPM.
> > I've used the Extended Properties with Like: FOB.Fob and that made it possible to right click on the new field to go to the FOB Entry, but the option "Refresh List" isn't showing. What do i need to do to get that one?
> > Kindly
> > //Lisa
