UD Service Designer - I cannot see my BO:Service in Swagger or application studio!
I have created a new service using the UD Service Designer, I basically have a table in there. Once the service created, I thought I’d be able to use rest-erp widget in Application Studio and call the basic functions like GetByID or GetANewRecord and so on. But my service doesn’t even show up in the drop down for ‘Service Name’. It doesn’t show up in Swagger either.
Is there something I have to do manually in order to have the new service available?
Regenerate DB, restart AppServer?
Yes both done.
Are you Cloud?
If you are, you need to run conversion workbench 210 (UpgradeUserDefinedServices), then maybe restart appserver. It is documented in Epicor’s ICE SDK User Guide within the Kinetic Help.
It will show here in REST Help:
Its weird, I had to re-generate again! The second time it worked!
Thank you!
We are on prem. The second regeneration fixed it. Not sure why I had to do it twice.
It’s Epicor.. don’t try to explain the things.. lol
