UD table data limit
Is there a size limit to the amount of data you can place in a UD table? We are trying to enter 200,000 rows into a UD table and it stops at 17,050
No, there’s no limit. We have UD tables with millions of rows. What error are you getting?
I’m not sure of the exact error, but part of his issue was running it from a VPN connection and then trying to run one DMT with 200,000 rows.
I asked him to break the DMT into multiple files, using the DMT tool. Because it was only showing 17,050 rows, I wanted to make sure there were no size limitations on the tables.
Thank you for the answer.
Oh yeah, definitely split the file up. Especially if running them over a VPN. DMT over a VPN is bad enough with small files.
