Thanks to Doug, here is how he told me to do it. I have not gotten around to implementing it yet, but this looks like it should work:
"You can make the 4gl code a stand alone progress program .p or .r if you compile it.
Then you can create a command line that calls prowin32 with the database name, port number, login and the 4gl program.
This command line can be added to the windows scheduler."
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
"The World Leader in Back-lit Mirrors & Mirror TV Technology"
T 425 776-4946
A 11831 Beverly Park Rd, Bldg D, Everett, WA 98204 USA
www.electricmirror.com<http://www.electricmirror.com>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steve_E
Sent: Wednesday, July 22, 2009 9:52 AM
Subject: RE: [Vantage] Re: UD table scan for dates
Tom,
Thanks for the infor, but I need something to run that code once a day in
the back ground. I can't find anything that fires once a day to run the 4
GL code from. Any Ideas?
Steve
From: Thomas Rose [mailto:t.rose@...<mailto:t.rose%40electricmirror.com>]
Sent: July 22, 2009 10:07 AM
Here is some 4GL air code. Others smarter than I will likely find some
improvements:
FOR EACH UD01 WHERE UD01.Company="ZZ01":
IF UD01.Date01 > Now THEN DO:
RUN lib\UpdateTableBuffer.p(input BUFFER UD01:HANDLE, 'CheckBox01',True).
END.
END.
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
www.electricmirror.com<http://www.electric <http://www.electricmirror.com>
mirror.com>
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf Of vantage03
Sent: Wednesday, July 22, 2009 7:40 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: [Vantage] Re: UD table scan for dates
I posted this a few days ago and did not get a response. I am looking to try
to run a scan check like vantages built in quote expire system. I am using
on of the UD table that have an expiration date and want the system to
change a check box to true when one of the date fields pass the current
date. Has any one done anything like this?
Steve
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com>
.com<mailto:vantage%40yahoogroups.com>, "vantage03" <vantage@...> wrote:
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
Tom,
Steve
improvements:
END.
END.
Thom Rose
Controller
Electric Mirror LLC
HOTEL LUXURY
T 425 776-4946
mirror.com>
Behalf Of vantage03
Steve
>dates alder then today and set a check box field.
> Is there any way to setup a routine to scan the a UD table and look for
> Steve
