UD Tables 8.03.408
Thanks for the info!
--- In vantage@yahoogroups.com, "Rob Bucek" <rbucek@...> wrote:
> You wont actually be able to change information at the table/field level
> until V9 (i.e. look at it in the data dictionary or some other method of
> viewing tables and fields to show your custom label vs the out of the
> box character01.
> As a side note, if you plan on creating reports using crystal or BAQ
> driven crystal reports I highly suggest you use the ShortChar01 type
> fields and Character01 etc are really message fields for large string
> inputs and they don't play well for sorting and grouping. ShortChar
> fields were designed for 250 characters or less and are more true string
> fields.
> Rob Bucek
> Manufacturing Engineer
> PH: (715) 284-5376 ext 3111
> FAX: (715)284-4084
> <http://www.dsmfg.com/>
> (Click the logo to view our site) <http://www.dsmfg.com/>
> Of Virginia
> Sent: Friday, November 13, 2009 2:47 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] UD Tables 8.03.408
> We want to use the UD tables, have added UD01 to the main menu through
> menu maintenance and are in the beginning stages of laying out the
> maintenance/set-up screen.
> I complete adding the fields I need to my maintenance/set-up screen
> using the customization toolbox and have added labels to both text
> boxes. The label for Character01 is "Material Type" and the label for
> Character02 is "Size Range". When I go into the data dictionary viewer
> and select my UD01 table and select the Character01 field, there is no
> indication in the data dictionary as to what label I have given to this
> field and there is no description. Description field says "not in use".
> What I need to know is this: How to I get the "Label" section and the
> desctiption section in the Data Dictionary Viewer (right side of the
> screen) to show that Character01 has a label: "Material Type" and the
> description is: "This field is used to reflect they material type being
> quoted."
> Thanks,
> Virginia Joseph
> Deep Hole Specialists
> 440-543-8157
We want to use the UD tables, have added UD01 to the main menu through menu maintenance and are in the beginning stages of laying out the maintenance/set-up screen.
I complete adding the fields I need to my maintenance/set-up screen using the customization toolbox and have added labels to both text boxes. The label for Character01 is "Material Type" and the label for Character02 is "Size Range". When I go into the data dictionary viewer and select my UD01 table and select the Character01 field, there is no indication in the data dictionary as to what label I have given to this field and there is no description. Description field says "not in use".
What I need to know is this: How to I get the "Label" section and the desctiption section in the Data Dictionary Viewer (right side of the screen) to show that Character01 has a label: "Material Type" and the description is: "This field is used to reflect they material type being quoted."
Virginia Joseph
440-543-8157
box character01.
fields.
Rob Bucek
FAX: (715)284-4084
Of Virginia
quoted."
Virginia Joseph
440-543-8157
