UD Tables Blank Title 84332
Ah, thanks! Renaming the EpiAddNewNew reference is what I was missing.
--- In vantage@yahoogroups.com, "Anon" <epicor-team@...> wrote:
> In the wizard created code that initializes the whole thing (method named "InitializeUD01Adapter") there is this property "_edvGrdUD01.AddText" you will notice that it is "New UD01". This is used to create the toolbar item in the background and generate it's ID. That being said you will want to change the referenced instances of "New UD01" in the code to whatever you name the label.
> Example I change the value of _edvGrdUD01.AddText from "New UD01" to "New Child". In the code the wizard generates for the toolbar "baseToolbarsManager_ToolClickForUD01" you will need to change the "EpiAddNewNew UD01" to "EpiAddNewNew Child" as this is a reference to the tool ID generated in the backside.
> Hope that makes sense. If you don't update the references to the tool ID and change the _edvGrdUD01.AddText value the toolbar item will do nothing at all.
> --- In vantage@yahoogroups.com, "bw2868bond" <bwalker@> wrote:
> > In V8 this code produces an item on the "New" dropdown that has the text "New MItem"
> > Private UD10View As EpiDataView = New EpiDataView(true,"New MItem","New")
> > You can probably find the code that the wizard produces in E9 and change the text there.....
> > --- In vantage@yahoogroups.com, "Chad Smith" <csmith@> wrote:
> > > Quick follow up on that. When you do this, it adds the New UD01 to the New drop down menu on the toolbar. Is it possible to rename the New UD01 to something more appropriate? I think you can rename the UD reference in the tree view, but haven't figured out how to change it on the New menu.
> > > --- In vantage@yahoogroups.com, John Driggers <waffqle@> wrote:
> > > > Customization Mode > Tools > Wizards > 'Add UD Table as Child'
> > > > Just tell it which keys you want to use (i.e. EmpID -> UD01.Key1) and it
> > > > will wire up all the code for the CRUD functions.
> > > > *John Driggers*
> > > > *Chief Data Wrangler*
> > > > *I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
> > > > *:: 904.404.9233
> > > > :: waffqle@
> > > > :: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> > > > On Thu, Oct 11, 2012 at 9:46 AM, Jose Gomez <jose@> wrote:
> > > > > uh? now you lost me
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > *T: 904.469.1524 mobile
> > > > > E: jose@
> > > > > http://www.josecgomez.com
> > > > > <http://www.linkedin.com/in/josecgomez> <
> > > > > http://www.facebook.com/josegomez>
> > > > > <http://www.google.com/profiles/jose.gomez> <
> > > > > http://www.twitter.com/joc85>
> > > > > <http://www.josecgomez.com/professional-resume/>
> > > > > <http://www.josecgomez.com/feed/>
> > > > > <http://www.usdoingstuff.com>
> > > > > *Quis custodiet ipsos custodes?*
> > > > > On Thu, Oct 11, 2012 at 9:42 AM, Ted Koch <tkoch77@> wrote:
> > > > > > "Free" is great. Is it possible to also create a foreign key view of UD01
> > > > > > to EmpBasic using the employeeID? Or you would recommend the UD100 UD100A
> > > > > > approach?
> > > > > > ________________________________
> > > > > > From: Jose Gomez <jose@>
> > > > > > To: vantage@yahoogroups.com
> > > > > > Sent: Thursday, October 11, 2012 9:24 AM
> > > > > > Subject: Re: [Vantage] UD Tables
> > > > > > Epicor gives you this for free
> > > > > > Look at any of the UD100's tables
> > > > > > They'll have UD100, UD100A
> > > > > > Simply load up the UI and for free you get this
> > > > > > *Jose C Gomez*
> > > > > > *Software Engineer*
> > > > > > E: jose@
> > > > > > On Thu, Oct 11, 2012 at 9:21 AM, tkoch77 <tkoch77@> wrote:
> > > > > > > Hi everyone,
> > > > > > > I am curious how I might achieve something using UD tables and if its
> > > > > > > possible. Basically I want to get the same behavior as adding line
> > > > > items
> > > > > > to
> > > > > > > a PO.
> > > > > > > I want to enter an employees ID, and then create multiple records tied
> > > > > to
> > > > > > > that ID, similar to the way lines are created for a PO. So when I pull
> > > > > > the
> > > > > > > user ID into the UD form, I get a grid (or whatever) that shows all the
> > > > > > > records associated with that user.
> > > > > > > Any ideas, thoughts, suggestions welcomed.
> > > > > > > Thanks!
> > > > > > > -Ted
> > > > > > [Non-text portions of this message have been removed]
> > > > > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > > > > > have already linked your email address to a yahoo id to enable access. )
> > > > > > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > > > > > Crystal Reports and other 'goodies', please goto:
> > > > > > http://groups.yahoo.com/group/vantage/files/.
> > > > > > (2) To search through old msg's goto:
> > > > > > http://groups.yahoo.com/group/vantage/messages
> > > > > > (3) To view links to Vendors that provide Vantage services goto:
> > > > > > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Hello,
I have a UD Table (AML). In this UD Table I have two fields (Name and Number)
I added an UltraCombo box that allows users (from a drop down) select from the Name field from the UD Table. I want another field that I added to be populated with the Number field from my UD Table.
I can't seem to figure out how to do this. Any clue anyone? Thanks in advance!!!!
-Sal
We have an upcoming go live and one of the customer service requirement is to have comments specific to individual customers displayed on all customer paperwork. These are standard comments, but are different for each customer and could be different for each order. Most times there are multiple comments that are required. I am looking for a way to fulfill this requirement. Does anyone have any ideas? I tried creating a UD table to track the comments by customer, but can't seem to get it to function the way we need it to. I need to have all the individual comments display in order entry so the customer service team can select the one(s) that they need displayed at that time.
Thank you,
Lauren Hellings
Business Analyst
Office: 281-207-4613
Cell: 832-472-1736
Fax: 281-207-0672
email: lauren.hellings@...<mailto:lauren.hellings@...>
www.c-p-i.com<http://www.c-p-i.com/>
----------Legal Disclaimer----------
The information contained in this message may be privileged and confidential, and is intended solely for the use of the named addressee. No other person is authorized to access, copy or re-use this message (or any information contained herein). If you are not the intended recipient, please notify us immediately by replying to this message and delete it from your computer.
Have you looked into parent/child UD tables? It sounds like you want multiple 'standard' comments for each customer and be able to pick the appropriate one at the time? Did I get that right?
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-0590
FAX: (715)284-4084
[Description: cid:1.234354861@...]<http://www.dsmfg.com/>
(Click the logo to view our site)<http://www.dsmfg.com/>
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Hellings, Lauren
Sent: Tuesday, June 12, 2012 6:19 AM
Subject: [Vantage] UD Tables
Thank you,
Lauren Hellings
Business Analyst
Cell: 832-472-1736
Fax: 281-207-0672
email: lauren.hellings@...<mailto:lauren.hellings%40c-p-i.com><mailto:lauren.hellings@...<mailto:lauren.hellings%40c-p-i.com>>
Our solution to a similar situation is fairly low tech, but it works. Using form customization I added a tab for customer comments which pulls in all comments for the customer. The salesmen copy from that tab and paste it into the order comment tab. They can choose which comments they need for the order. From there they can choose to duplicate the comments on the sales order or job pick lists, pack list and invoice. They have requested that I turn the tab red when there are customer comments present, but I haven't got around to that yet. I did find some threads on the topic, but haven't attempted it. Until I do, they have to remember to check the customer comments tab for comments.
Sue
--- In vantage@yahoogroups.com, "Hellings, Lauren" <lauren.hellings@...> wrote:
> Thank you,
> Lauren Hellings
> Business Analyst
> Cell: 832-472-1736
> Fax: 281-207-0672
Hi,
I haven't really delved into the usage of UD tables yet. Hoping someone could help me understand how they work and if they will work for what I am trying to do.
My thought is I want to store some information into a UD table and then create a dashboard based around a UD table where users would review the dashboard. The information would be coming from AutoCAD so I would probably be using service connect to populate the table.
The information contained in the dashboard would be parts drawn in AutoCAD that need reviewed. I would want each row in the UD table to represent a part in AutoCAD that needs reviewed. The dashboard would allow the user to to decide if this item is a Make or Buy by selecting a button, which would then delete this record from the UD table and then either send it to our CNC list (make) or create a sub assembly (buy) in a job. The job number and operation information is already contained within autocad.
My question is can i define any fields in a UD table, such as job number, part number, part desc, material number, material desc, operations, dwg file location, etc? Or am I better off creating a new SQL database for something like this and just create a custom windows application?
Thanks for any input,
Ted
I am new to UD Tables. Is there documentation someplace where I can see examples of their use? I am trying to create an applicaton that will have a parent table with 2 child tables associated with the parent. Looking at the UD Table names I see some tables with a suffix of A behind the name. Can I use any of the tables for this set of tables in my application or are the "A" tables preferred? Again I am looking for any insight on the preferred way to use the UD tables.
9.04.507A
Mike
UD 01-99 are singel tables
UD100 - END are Child Parent Tables (though only 1 child)
To accomplish what you want what I've done is used something like UD100,A
and UD01 as the second child.
*Jose C Gomez*
*Software Engineer*
E: jose@...
> 9.04.507A
> Mike
Hi everyone,
I am curious how I might achieve something using UD tables and if its possible. Basically I want to get the same behavior as adding line items to a PO.
I want to enter an employees ID, and then create multiple records tied to that ID, similar to the way lines are created for a PO. So when I pull the user ID into the UD form, I get a grid (or whatever) that shows all the records associated with that user.
Thanks!
-Ted
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Thu, Oct 11, 2012 at 9:21 AM, tkoch77 <tkoch77@...> wrote:
> Hi everyone,
> a PO.
> Thanks!
> -Ted
"Free" is great. Is it possible to also create a foreign key view of UD01 to EmpBasic using the employeeID? Or you would recommend the UD100 UD100A approach?
*Jose C Gomez*
*Software Engineer*
E: jose@...
<http://www.linkedin.com/in/josecgomez>Â <http://www.facebook.com/josegomez>
> Hi everyone,
> a PO.
> Thanks!
> -Ted
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
You can hook a UD table to any table you want.
There's a customization wizard for 'add UD table as child'.
*John Driggers*
*:: 904.404.9233
:: waffqle@...
> approach?
> From: Jose Gomez <jose@...>
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi everyone,
> to
> > a PO.
> the
> > Thanks!
> > -Ted
uh? now you lost me
*Jose C Gomez*
*Software Engineer*
E: jose@...
> approach?
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi everyone,
> to
> > a PO.
> the
> > Thanks!
> > -Ted
*John Driggers*
*:: 904.404.9233
:: waffqle@...
On Thu, Oct 11, 2012 at 9:46 AM, Jose Gomez <jose@...> wrote:
> uh? now you lost me
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > approach?
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Hi everyone,
> items
> > to
> > > a PO.
> to
> > the
> > > Thanks!
> > > -Ted
I just did something exactly like this. I ran into a few issues where the wizard generated code created some parent dataviews that conflicted with some existing code. On a base, brand new, customization the wizard works flawlessly, on 9.05.700 at least. With an existing customization some tinkering may be required, I ran into that.
> *John Driggers*
> *:: 904.404.9233
> :: waffqle@...
> > uh? now you lost me
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > approach?
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > > Hi everyone,
> > items
> > > to
> > > > a PO.
> > to
> > > the
> > > > Thanks!
> > > > -Ted
Also something I took away from that experience was that it doesn't appear you can use EpiNotification with the UD table added, even though it is available, however the entry points that EpiNotification gives you are available in the custom functions the wizard creates.
CreateNewUD01 -> Notify New
GetUD01Data -> Notify Initialize
etc....
> > *John Driggers*
> > *:: 904.404.9233
> > :: waffqle@
> > > uh? now you lost me
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > > approach?
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > > Hi everyone,
> > > items
> > > > to
> > > > > a PO.
> > > to
> > > > the
> > > > > Thanks!
> > > > > -Ted
> *John Driggers*
> *:: 904.404.9233
> :: waffqle@...
> > uh? now you lost me
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > approach?
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > > Hi everyone,
> > items
> > > to
> > > > a PO.
> > to
> > > the
> > > > Thanks!
> > > > -Ted
> > *John Driggers*
> > *:: 904.404.9233
> > :: waffqle@
> > > uh? now you lost me
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > > approach?
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > > Hi everyone,
> > > items
> > > > to
> > > > > a PO.
> > > to
> > > > the
> > > > > Thanks!
> > > > > -Ted
> > > *John Driggers*
> > > *:: 904.404.9233
> > > :: waffqle@
> > > > uh? now you lost me
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > > > approach?
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> > > > > > Hi everyone,
> > > > items
> > > > > to
> > > > > > a PO.
> > > > to
> > > > > the
> > > > > > Thanks!
> > > > > > -Ted
Thanks for that tip!
Sent: Thursday, October 11, 2012 11:28 AM
Subject: [Vantage] Re: UD Tables
In the wizard created code that initializes the whole thing (method named "InitializeUD01Adapter") there is this property "_edvGrdUD01.AddText" you will notice that it is "New UD01". This is used to create the toolbar item in the background and generate it's ID. That being said you will want to change the referenced instances of "New UD01" in the code to whatever you name the label.Â
> > > *John Driggers*
> > > *:: 904.404.9233
> > > :: waffqle@
> > > > uh? now you lost me
> > > > *Jose C Gomez*
> > > > *Software Engineer*
> > > > E: jose@
> > > >Â <http://www.linkedin.com/in/josecgomez> <
> > > >Â <http://www.google.com/profiles/jose.gomez> <
> > > >Â <http://www.josecgomez.com/professional-resume/>
> > > >Â <http://www.usdoingstuff.com>
> > > > > approach?
> > > > > *Jose C Gomez*
> > > > > *Software Engineer*
> > > > > E: jose@
> > > > > > Hi everyone,
> > > > items
> > > > > to
> > > > > > a PO.
> > > > to
> > > > > the
> > > > > > Thanks!
> > > > > > -Ted
