UD100 BeforeAdapter Delete (Header/Detail)
When I use the BeforeAdapter on the UD100 table, is there a way to tell me if the user is deleting the header or a detail item? I see there is only one adapter for UD100 and not the UD100A. I am running this code to iterate through the lines but when they just delete one line I only want to process it for that one detail record. I realize this will need to be conditioned for that but can’t differentiate through the adapter if a header or a line is being deleted. The rowmods are blank on both in my messagebox unless I am calling that incorrectly.
	private void oTrans_adapter_BeforeAdapterMethod(object sender, BeforeAdapterMethodArgs args)
		switch (args.MethodName)
			case "Delete":
				//MessageBox.Show(edvUD100.dataView[edvUD100.Row]["RowMod"].ToString() + " / " + edvUD100A.dataView[edvUD100A.Row]["RowMod"].ToString());
				if(edvUD100A.dataView.Count > 0)
					foreach(DataRowView rowView in edvUD100A.dataView)
						DataRow row = rowView.Row;
						int no = 0;
						if(int.TryParse(row["ChildKey2"].ToString(), out no) && int.TryParse(row["ChildKey1"].ToString(), out no))
							int bolNum = Convert.ToInt32(row["ChildKey2"]);
							deleteBOL(bolNum, packNum);
				refreshGrids();
				break;
Ross
You should be able to get a hold of the Adapter data itself and iterate through the list and look at the RowState
var adapter = (UD100Adapter)csm.TransAdaptersHT["oTrans_adapter"];
foreach(var x in adapter.UD100Data.UD100)
    if(x.RowState == DataRowState.Deleted
foreach(var x in  adapter.UD100Data.UD100A)
note I just typed this in here from memory so the syntax may not be exact but you get the idea.
Excellent, thanks Jose! I will give that a try and no problem on memory stuff…I can sort out the details.
Regards,
Ross
I tried this and get ‘Unchanged’ for everything when I delete the header or any line.
foreach(DataRow row in adapter.UD100Data.UD100)
	MessageBox.Show(row.RowState.ToString());
foreach(DataRow row in  adapter.UD100Data.UD100A)
Not sure if I am doing anything wrong here and will keep looking but thought I would report back.
Ross
