You'll have to change all the names to match the new ice. Ud100 convention. Next thing is make a quick customization in 10 and then look at how it nabs the controls, form etc and replace that in the 9.x export.
I've done this successfully just be careful
On Apr 6, 2015 6:14 PM, "Anthony Gercar agercar@... [vantage]" <vantage@yahoogroups.com> wrote:Â<div> <p>
Did it work in previous builds of E10?Â
Sent from my iPhoneÂGot the error.
Customization UDPartSz2 for the application.
App.UD100Entry.UD100Form failed validation for build 3.0.7.0.
So in the
<FormsID>UD100Form</FormsID>
<ControlName>epicor.mfg.ad.ud100.dll</ControlName>
<Key>EpiString.ExecutionPath*epicor.mfg.ad.ud100.dll</Key>
I tried changing the dll path to ‘Ice.UI.UD100Entry.dll’ got the same message.
[cid:image001.png@01D07087.F106E080]
Sent: Monday, April 06, 2015 3:40 PM
To: Vantage
Subject: Re: [Vantage] UD100 table data in Epicor 10
Try exporting in E9 and Importing into E10 if it wont let you import cause the DLL name changed, open the customization on Notepad and change the DLL name to match the new one.. you may get lucky...
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
E: jose@...<mailto:jose@...>
http://www.josecgomez.com
[http://www.josecgomez.com/images/linkedin.png]<http://www.linkedin.com/in/josecgomez> [http://www.josecgomez.com/images/facebook.png] <http://www.facebook.com/josegomez> [http://www.josecgomez.com/images/google.png] <http://www.google.com/profiles/jose.gomez> [http://www.josecgomez.com/images/twitter.png] <http://www.twitter.com/joc85> [http://www.josecgomez.com/images/wp.png] <http://www.josecgomez.com/professional-resume/> [http://www.josecgomez.com/images/rss.png] <http://www.josecgomez.com/feed/>
On Mon, Apr 6, 2015 at 4:34 PM, Stephen Freeman stephenf@...<mailto:stephenf@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
This one had a good bit of custom code. My interface is totally blown away.
From: vantage@yahoogroups.com<mailto:vantage@yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>]
Sent: Monday, April 06, 2015 3:30 PM
To: Vantage
Epicor shouldn't have moved your data... can you clarify? Your data still exists in ICE.UD100, ICE.UD100A the only thing they did was move it to a different schema but that shouldn't affect your customization (Beyond the normal things you need to do to get customization to carry over / work).
If you can't find it in your E10DB try importing it from E9 most of them will came over without too much issue as long as there is not a lot of custom code.
Jose C Gomez
Software Engineer
T: 904.469.1524<tel:904.469.1524> mobile
On Mon, Apr 6, 2015 at 4:00 PM, Stephen Freeman stephenf@...<mailto:stephenf@...> [vantage] <vantage@yahoogroups.com<mailto:vantage@yahoogroups.com>> wrote:
Current live environment is 905.702A(OpenEdge), have a test server with my company’s data running in 10.0.700.4(SQL). In 905 and prior version I had a customization that used the UD100 and UD100A tables, but Epicor moved this in Epicor 10. Does anyone have a quick set of instructions for me to relink my customizations to wherever Epicor is putting my data now?
</div> <div style="color:#fff;min-height:0;"></div>
