UDfields are unavailable after regen / recycle process
Hello,
I have added UDfields to two tables (OrderHed and ShipVia ) in my DEV environment.
Ran the Generate Data Model without errors. Then Recycle IIS App Pool.
Logoff Epicor training, log back in, I verify the User Defined Column maintenance and both tables show Green, in sync.
But trying to use the new udfield in a data directive, the fields are not part of the list.
I did regen/recycle process 3 times ! I even rebooted the server and got the same results.
What else can I do ?.
Pierre
Can you reference the field by name? I think the entity framework model of the Db isn’t always the same as the actual Db
@Hogardy This KB has a word doc on where to check and a traceflag to add to help diagnosis. Basically there is sometimes an issue where the datatype is not in sync between the UD table and ZDataField, I always check the UD table column and the view to make sure they match.
Greg
https://epicorcs.service-now.com/epiccare?id=epiccare_kb_article&sys_id=ef8c5173dbcd87484b91fb5aaf96195e
Thanks got the KB and the datatypes matches on my 3 added fields.
I have opened a ticket to Epicor about it.
Pierre
Update:
This morning got a call by support, connected to my computer, and pouf! by magic, all was working fine…did not do anything…
:roll_eyes: :crazy_face:
now that’s EpiMagic!
BTW: Noticed the change in colors and in the logo of Epicor on EpicCare site… nice…
I have come across this problem many times. The solution I use, which might help you is to edit the Target properties of my Epicor start shortcut like this,
Make sure there is a space between sysconfig and the forward slash. It forces the client update, which I was told it should always do anyway but I found it does not without this edit.
