UltraDataGrid Column Format for a udgEpiCustom Control
Thanks for the reply.
The below suggestion works when you bind the ultragrid to an existing
Datasource/View via the Customization Tools Dialog; however in
the "Part Maintenance" or other programs, except for UD02Entry, a
view for table UD02 is not available so I have to get the records via
UD02Adapter. Once I receive the a dataset from the adapter, I am
doing:
ugdEpiCustom1.Datasource = ud02Adapter.UD02Data.UD02
This populates the grid, but I just don't want every column to be
displayed. I noticed that the adapter has a method
called "FormatGridColumns()"; I am just not sure how to use it. I
was hoping someone may have an example of it.
Thanks again,
Percy
--- In vantage@yahoogroups.com, "Matt Barron" <mbarron@...> wrote:
> Percy-
> Go into the Customization Tools Dialog and click on the List tab on
your
> form. Then click on the UltraGrid that you are trying to customize.
> Once you do this, you will see on your Customization Tools Dialog
that
> there is a table with check boxes for each element in the
UltraGrid.
> You can click the check boxes under the "Hidden" column to hide the
> information you dont want to display...Make sure you click "Apply"
at
> the bottom and then the Save icon...
> Exit out of your customization and get back into it and you should
see
> the changes...
> Hope that helps...
Behalf
> Of therealhackercat
> Sent: Tuesday, October 02, 2007 9:51 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] UltraDataGrid Column Format for a udgEpiCustom
> Control
> Hello Everyone,
> I have a custom UltradataGrid named udgEpiCustom1 which has a
> Datasource pointing to an Adapter, UD02Adapter; however when the
> UltradataGrid gets populated, all the columns are shown; among
them,
> company name, key1, key2,key3, etc.
> I would like for the datagrid only to show selected columns, eg:
key1,
> Char01, Number01
> Does anyone know how I format the grid to show only the above
columns?
> By the way, the adapter is performing on search fist based on some
> criteria; so the adapter is used dynamically.
> Thank you for all your help,
> Percy
Hello Everyone,
UltradataGrid gets populated, all the columns are shown; among them,
I would like for the datagrid only to show selected columns, eg: key1,
Char01, Number01
Does anyone know how I format the grid to show only the above columns?
Percy
Percy-
Go into the Customization Tools Dialog and click on the List tab on your
Once you do this, you will see on your Customization Tools Dialog that
there is a table with check boxes for each element in the UltraGrid.
information you dont want to display...Make sure you click "Apply" at
Exit out of your customization and get back into it and you should see
the changes...
Hope that helps...
Of therealhackercat
Control
Hello Everyone,
Char01, Number01
Percy
