Ultragrid Read Only-- Again! (Was: UltraGrid: read only col
What happens if you remove the statement:
edv.dataView. Table.Columns( "linedescr" ).ExtendedProper ties("Enabled" ) = True
(Enabling a column that is read only may be triggering the odd behavior.)
If that doesn't work, what does the trace log say?
(Perhaps one of the app's BO methods is overriding your readonly=True & you might have to fire off your readonly=true code after the method executes - using after BO method as the trigger.)
Just a stab in the dark but that is where I'd start.
Rob Brown
Sent: Thursday, August 6, 2009 4:09:42 PM
Subject: [Vantage] Ultragrid Read Only-- Again! (Was: Re: UltraGrid: read only column)
I've added an ultragrid for quotedtl to the quoteform that has linedescr as visible and I'm trying to make it read only. No matter what I do it just makes the whole grid inactive, thus users can't click to select a line
anybody got this to work?
code:
Sub InitializeCustomCod e()
SetExtendedProps( )
End sub
Private Sub SetExtendedProps( )
Dim edv As EpiDataView = CType(oTrans. EpiDataViews( "OrderDtl" ), EpiDataView)
If edv.dataView. Table.Columns. Contains( "linedescr" ) Then
edv.dataView. Table.Columns( "linedescr" ).ExtendedProper ties("ReadOnly" ) = True
End if
End sub
Cheers,
-Ramsey
--- In vantage@yahoogroups .com, "bw2868bond" <bwalker@... > wrote:
> In case anyone else is interested:
> Module Script
> '// ** Wizard Insert Location - Do Not Remove 'Begin/End
> Wizard Added Module Level Variables' Comments! **
> '// Begin Wizard Added Module Level Variables **
> Private WithEvents edvCustomerPriceLst As EpiDataView
> '// End Wizard Added Module Level Variables **
> '// Add Custom Module Level Variables Here **
> '// ** Wizard Insert Location - Do not
> delete 'Begin/End Wizard Added Variable Intialization' lines **
> '// Begin Wizard Added Variable Intialization
> edvCustomerPriceLst = CType(oTrans. EpiDataViews
> ("CustomerPriceLst" ), EpiDataView)
> '// End Wizard Added Variable Intialization
> '// Begin Custom Method Calls
> edvCustomerPriceLst .dataView. Table.Columns
> ("ShortChar01" ).ExtendedProper ties("ReadOnly" ) = True
> ("ShortChar02" ).ExtendedProper ties("ReadOnly" ) = True
> ("Date01").Extended Properties( "ReadOnly" ) = True
> ("Date02").Extended Properties( "ReadOnly" ) = True
> '// End Custom Method Calls
> End Sub
> Sub DestroyCustomCode( )
> delete 'Begin/End Wizard Added Object Disposal' lines **
> '// Begin Wizard Added Object Disposal
> '// End Wizard Added Object Disposal
> '// Begin Custom Code Disposal
> '// End Custom Code Disposal
> End Sub
> End Module
> --- In vantage@yahoogroups .com, Fons van der Beek
> <fons.vanderbeek@ > wrote:
> > do you have an example how to make a dataview column readonly?
> > i don't know how to do this....
> > bw2868bond schreef:
> > > You can set the readonly property to true in the ultragrid
> designer,
> > > but when the epidataview is bound to the ultragrid, the readonly
> > > property is reset to the readonly property of the column in the
> > > epidataview.
> > > You need to set the dataview column to readonly by way of code
> then the
> > > epidatagrid column should stay readonly when it is databound.
> > > At least that is the way I have been able to make it work for
> me....
> <fons.vanderbeek@ >
> > > wrote:
> > >> Hi,
> > >> I"ve customized the ultra grid for pricelists in customer
> maintenance.
> > >> I've added some columns, but I want to make them readonly.
> > >> Alltough it's possible to mark columns as readonly,
> this "readonly"
> > >> checkmark is not saved when saving the customization.
> > >> Is there a way to manualy make columns read only from a
> ultragrid, is
> > >> there a property of ultragrid that can be set?
> > >> For instance when loading the form containing the ultragrid.
> > >> Thanks in advance
> > >> Fons van der Beek
Hi,
I"ve customized the ultra grid for pricelists in customer maintenance.
Alltough it's possible to mark columns as readonly, this "readonly"
Is there a way to manualy make columns read only from a ultragrid, is
Thanks in advance
Fons van der Beek
Google found this:
http://www.csharpfriends.com/Forums/ShowPost.aspx?PostID=30785
this.ultraGrid1.DisplayLayout.Bands[0].Columns[0].CellClickAction =
Infragistics.Win.UltraWinGrid.CellClickAction.CellSelect;
or
this.ultraGrid1.DisplayLayout.Bands[0].Columns[0].CellActivation =
Infragistics.Win.UltraWinGrid.Activation.ActivateOnly;
Unfortunatly this was not the solution, i allready found
that............ The message was "ultraGrid1" is not a property
I also tried EpiUltraGrid and EpiUltraGrid1
It looks like Epicor changed the properties from infragistics
futhermore the assignement i was able to make was only "true" or "false"
but thanks for looking it up.....................
> Google found this:
> or
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
You say you added columns - did you add them through code or only
make existing data not hidden anymore?
--- In vantage@yahoogroups.com, Fons van der Beek
or "false"
ultragrid, is
> > Google found this:
> > or
access. )
by only maken existing data not hidden
( I just enabled the fields with a different caption)
> or "false"
> ultragrid, is
>>> Google found this:
>>> or
> access. )
You can set the readonly property to true in the ultragrid designer,
epidataview.
You need to set the dataview column to readonly by way of code then the
At least that is the way I have been able to make it work for me....
--- In vantage@yahoogroups.com, Fons van der Beek <fons.vanderbeek@...>
wrote:
> Hi,
> Thanks in advance
> Fons van der Beek
> epidataview.
> wrote:
>> Hi,
>> Thanks in advance
>> Fons van der Beek
Module Script
Sub InitializeCustomCode()
edvCustomerPriceLst = CType(oTrans.EpiDataViews
("CustomerPriceLst"), EpiDataView)
edvCustomerPriceLst.dataView.Table.Columns
("ShortChar01").ExtendedProperties("ReadOnly") = True
("ShortChar02").ExtendedProperties("ReadOnly") = True
("Date01").ExtendedProperties("ReadOnly") = True
("Date02").ExtendedProperties("ReadOnly") = True
End Sub
Sub DestroyCustomCode()
End Sub
End Module
designer,
> > epidataview.
then the
me....
<fons.vanderbeek@>
> > wrote:
> >> Hi,
maintenance.
this "readonly"
ultragrid, is
> >> Thanks in advance
> >> Fons van der Beek
code:
SetExtendedProps()
End sub
Private Sub SetExtendedProps()
Dim edv As EpiDataView = CType(oTrans.EpiDataViews("OrderDtl"), EpiDataView)
If edv.dataView.Table.Columns.Contains("linedescr") Then
edv.dataView.Table.Columns("linedescr").ExtendedProperties("ReadOnly") = True
edv.dataView.Table.Columns("linedescr").ExtendedProperties("Enabled") = True
End if
End sub
Cheers,
-Ramsey
> Module Script
> End Sub
> End Sub
> End Module
> designer,
> > > epidataview.
> then the
> me....
> <fons.vanderbeek@>
> > > wrote:
> > >> Hi,
> maintenance.
> this "readonly"
> ultragrid, is
> > >> Thanks in advance
> > >> Fons van der Beek
