Unable to connect to remote ODBC database
I'm running a test database on a remote 2008 SERVER that VirtualBox is hosting. I'm successfully able to connect through Vantage, but when testing the connection in ODBC I get a login failed error.
I've opened the correct port, 8350, and verified the sysprogress id/password are correct.
I'd like to use this test database to test Crystal reports, since running against our live database causes our system to run slowly.
--sf
