Hi Jim
For v4 you need to find your Services file, open it with Notepad or Wordpad
and add:-
vantage 2900/tcp
vntgtrain 2910/tcp
at the bottom.
Make sure you use spaces and not Tabs to separate the text, also a carriage
return is needed after the last entry. Save after editing.
HTH Chris Reed
PWSL
and add:-
vantage 2900/tcp
vntgtrain 2910/tcp
at the bottom.
HTH Chris Reed
PWSL
----- Original Message -----
To: <vantage@egroups.com>
Sent: Friday, July 28, 2000 6:41 PM
Subject: [Vantage] Unable to find VntgServ
> Could someone help some novices out with the following problem. After
> installing netscape on one of our network computers we encounter the
> following error when trying to load vantage. Unable to find VntgServ
> with protocol TCP in file services or services file not in expected
> location (5192). Could someone steer us in the right location. As I
> stated you are dealing with novices here so please keep it simple.
> Thanks in advance.
> Jim Smith
> Lovejoy Chaplet Corp.
> (518) 686-5232
