Unable to launch vantage
Vantage requires 'Small Fonts' in Windows 2000 or 'Normal Fonts' in XP.
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Monday, June 21, 2004 11:54 AM
Subject: RE: [Vantage] Unable to launch vantage
> Yup, widget problems in the past were always video related. I tried
> different settings on the card, but none work...
> -----Original Message-----
> From: Paul Lipham [mailto:pml@...]
> Sent: Monday, June 21, 2004 2:48 PM
> To: vantage@yahoogroups.com
> I've seem similar errors before. It's usually linked to your video
> settings. Make sure they haven't selected to use "large icons" under the
> video setup ...this is usually the culprit. Also, if they are running a
> very high resolution try bumping it down a size or two.
> Paul L
> From: Paul Siebers [mailto:paul.siebers@...]
> Sent: Monday, June 21, 2004 1:41 PM
> To: 'vantage@yahoogroups.com'
> Subject: [Vantage] Unable to launch vantage
> Has anyone seen these error messages before, when trying to launch
> Vantage?
> 0x8007007e seems too be a well documented MS problem, but I am not sure
if
> it is the underlying problem with unsuccesfully trying to start a
Vantage
> client session as well....
> Error
> Error occurred while creating CONTROL-FRAME: Spliter1.
> The specified module could not be found. Error code: 0x8007007e (5898)
> OK
> Error
> **Unable to realize CONTROL-FRAME widget. (4025)
> OK
> TIA,
> Paul
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder
and
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> Yahoo! Groups Links
> a.. To visit your group on the web, go to:
> b.. To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Yahoo! Groups Links
> Yahoo! Groups Links
Has anyone seen these error messages before, when trying to launch Vantage?
0x8007007e seems too be a well documented MS problem, but I am not sure if
it is the underlying problem with unsuccesfully trying to start a Vantage
Error
OK
Error
OK
TIA,
Paul
Paul L
Vantage?
Error
OK
Error
OK
TIA,
Paul
ADVERTISEMENT
Yahoo! Groups Links
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Paul L
Vantage?
Error
OK
Error
OK
TIA,
Paul
ADVERTISEMENT
Yahoo! Groups Links
Yahoo! Groups Links
