Unable to login to "Training Database"
I had a similar issue and ended up using the admin console and expiring the password. When you attempt to login it will prompt you to change the password.
I could not login when I attempted to do the database conversion (reset the serial numbers step in the guide).
I hope this helps.
SH
--- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@...> wrote:
> Need to use the Training Database that Epicor includes with their software package.
> The database successfully mounts, the App Servers start successfully, I'm able to login to use the Admin tools, but when trying to login with manager:manager, an error message is returned "7175," and nothing more.
> --sf
--sf
try epicor epicor they changed it in 9.05
from manager maganer
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
> package.
> --sf
This is an older version 8.0345
When trying another username/password it does return that authentication has failed, so that much is working.
--sf
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > package.
> > --sf
Anything in the appserver logs? That should generate something.
sanfranc415
Sent: Friday, July 20, 2012 1:57 PM
Subject: [Vantage] Unable to login to "Training Database"
package.
--sf
The new password is manager epicor in 9.
Mark W.
package.
--sf
I would take a look at your desktop shortcut and config files - I saw an error like that once when we were trying to separate the appservers. If you got to the point where you put in your login ID & password, the screen came up and then you got the app server then the problem could be with the process and/or task app servers (system monitor loads up right after login)
